Russell's Paradox: Understanding the Contradiction of Sets
  • Thread starter cesc
  • Tags
    Paradox
In summary: X and Y are not themselves sets.In summary, the class definition of LinkedNode contains itself, even if you take it to be an ordered n-tuple of its properties.
cesc
I understand how the argument goes- let X be the set of all sets which don't contain themselves.
If X contains itself, then X is not in X
If X doesn't contain itself, then X is X
the part i don't understand is, What on Earth does it mean for a set to contain itself?
garbage in, garbage out?
It means that the set is an element of itself. For example, an expense list might be viewed as a set of items (the items listed on it). If the expense list itself is listed as an item on the expense list, then that set contains itself.
The resolution is to add a type system which prevents sets from containing themselves, even indirectly.
well the example seems kind of frivolous.
Also, I'm not sure if its quite right. The word "list" has the dual meaning of a set, and a piece of paper which is an expenseAre there any examples involving mathematical objects?
[tex]X \in X[/tex].
Sets containing themselves don't cause a problem. And even if you want to exclude them, you can just use the axiom of foundation, rather than trying to do something more elaborate.
Could you give a concrete example where X is an element of X
X = {X}
No problem there.
If you look at the ZF axioms, it's not too hard to see that there is no set that contains itself.
Suppose X is a set, and consider the set {X}. Now (following Wikipedia, anyway), the axiom of regularity says: "Every non-empty set x contains a member y such that x and y are disjoint sets." Well, {X} is a nonempty set, and its only member is X. Thus, {X} and X are disjoint; since X is in {X}, X is not in X.
The axiom of foundation (regularity) doesn't help avoid Russell's paradox. If the paradox can be constructed in a theory X, then it can be constructed in the theory X + foundation (and leads to contradiction, naturally).
Russell's paradox doesn't occur in ZF because such paradoxical sets cannot be constructed in the first place -- the axiom of specification isn't powerful enough.
Here's a more practical example.
class LinkedNode
public LinkedNode next;
public String data;
The class in Java defines a "set" which may contain elements, "objects". Saying object A is an instantiation of class B is basically to say that B = {X | X has the given properties} and A is in B.
Here, LinkedNode contains itself. Even if you take a class definition to be a an ordered n-tuple of its properties rather than a set, you still have
(next, data) = {next, {next, data}} or {{next, data}, data} (definition of ordered n-tuple, I think?)
In the first example, next is in LinkedNode because it's the first element in the list... in the second, because it is in the first set, which is in the outside set.
So, despite it all, you can certainly have things like X = {X} and Z = Z x Y...
1. What is Russell's Paradox?
Russell's Paradox is a logical contradiction that was discovered by British philosopher and mathematician Bertrand Russell in 1901. It demonstrates the limitations of set theory and raises questions about the nature of mathematical logic.
2. How does Russell's Paradox challenge set theory?
Russell's Paradox challenges set theory by showing that certain sets, such as the set of all sets that do not contain themselves, cannot exist within the framework of traditional set theory. This undermines the notion that any well-defined collection of objects can be considered a set.
3. What is the paradoxical set in Russell's Paradox?
The paradoxical set in Russell's Paradox is the set of all sets that do not contain themselves. This set leads to a contradiction: if it contains itself, then it should not contain itself, and if it does not contain itself, then it should contain itself.
4. What are the implications of Russell's Paradox?
Russell's Paradox has significant implications for the foundations of mathematics and logic. It calls into question the assumptions and principles upon which set theory and other mathematical theories are built. It also highlights the limitations of using language and symbols to represent and understand abstract concepts.
5. How has Russell's Paradox been resolved?
Several solutions have been proposed to resolve Russell's Paradox, including the development of new axioms and theories of sets, such as Zermelo-Fraenkel set theory. Another approach is to restrict the language and symbols used in set theory to avoid self-referential statements that lead to contradictions. Ultimately, the resolution of Russell's Paradox remains a topic of ongoing debate and research in the fields of mathematics and philosophy.
  • Set Theory, Logic, Probability, Statistics
