Rydberg's Constant: Diff. between R∞ & R_H
  • Thread starter M. next
  • Tags
    Constant
In summary, the difference between R∞ and R_{H} is that R_\infty is calculated assuming a fixed nucleus with infinite mass, while R_\mathrm{H} is calculated for an actual proton that can move. This leads to a different center of mass and affects the behavior of the atom's internal dynamics.
M. next
382
What is the difference between R∞ and R[itex]_{H}[/itex]? Physically and mathematically.
Thanks
Thanks
[itex]R_\infty[/itex] is calculated assuming a fixed nucleus (thus assuming an infinite mass), while [itex]R_\mathrm{H}[/itex] is calculated for an actual proton that can move (thus in the center-of-mass frame).
In any equation where an infinite mass of the proton was assumed, you only need to replace the mass of the electron with the reduced mass of the electron+proton system to get the correct value ("correct" in the sense that you are not making the approximation that the proton cannot move).
Thank you a LOT! Sorry it took me time to recheck this thread. I would just like to know one more thing:why is it that a fixed nucleus implies an infinite mass?
Turn it the other way around: an infinite-mass nucleus would be "fixed" as far as the atom's internal behavior is concerned.
If the nucleus and electron had the same mass (e.g. if we used a positron instead of a proton in hydrogen... look up positronium), they would both "revolve" around a point halfway between them, the center of mass of the system. (Of course this is a quantum-mechanical system so they don't revolve in the usual sense, but there is an analogous effect.)
As the mass of the nucleus increases relative to the electron, the center of mass shifts closer to the nucleus. In the limit as the mass of the nucleus goes to infinity, the center of mass approaches the center of the nucleus, in which case the nucleus wouldn't revolve at all.
Oh my! That was a great answer! Thanks
What is Rydberg's Constant?
Rydberg's Constant is a physical constant that appears in the Rydberg formula, which is used to calculate the wavelengths of spectral lines of atomic hydrogen.
What is the difference between R∞ and RH?
R∞ is the Rydberg constant for free space, while RH is the Rydberg constant for hydrogen atoms. R∞ is used for calculating spectral lines of any atom, while RH is specific to hydrogen.
What is the numerical value of R∞ and RH?
R∞ has a value of 1.0973731568539 x 107 m-1, while RH has a value of 1.09677583 x 107 m-1.
How was Rydberg's Constant calculated?
Rydberg's Constant was first calculated by the Swedish physicist Johannes Rydberg in 1888. He used spectroscopic data from hydrogen atoms to derive the constant.
Why is Rydberg's Constant important?
Rydberg's Constant is important because it helps us understand the energy levels and spectral lines of atoms and molecules. It is also used in various fields of science, such as astronomy and quantum mechanics, to study the properties of matter and light.
  • Atomic and Condensed Matter
  • Quantum Physics
