Homework Help: Σ neutral decay
  1. Nov 25, 2014 #1
    A Σ0 baryon, travelling with an energy of 2 GeV, decays electromagnetically into a Λ and a photon.
    What condition results in the Λ carrying the maximum possible energy after the decay? Sketch how the decay appears in this case, and calculate this energy. Explain your reasoning.
    [Mass of Σ0 is 1.193 GeV/c2; mass of Λ is 1.116 GeV/c2]
    2. Relevant equations
    Relativistic kinematic equations;
    CoM invariant mass
    3. The attempt at a solution
    So im not sure on the condition for maximum energy of the Λ, is it when the photon is travelling with opposite momenta?
    because the photon is a mass less particle it couldn't have 0 velocity right?
  3. Nov 25, 2014 #2
    Orodruin
    Staff Emeritus
    2017 Award
    What energy will the ##\Lambda## have in the rest frame of the ##\Sigma##?
  4. Nov 25, 2014 #3
    So in the rest frame of the ##\Sigma##
    The energy would be
    $$E_{\Lambda}=E_{\Sigma^o}+p_{photon}c$$
    Right?
    Because if The ##\Sigma## decays at rest then the momenta of the ##\Lambda## and photon will be equal and opposite.
  5. Nov 25, 2014 #4
    Orodruin
    Staff Emeritus
    2017 Award
    What does energy and momentum conservation tell you?
  6. Nov 25, 2014 #5
    If we are looking at the rest frame of the ##\Sigma## energy conservation gave me tee equation above and doesn't momentum conservation just tell me that;
    $$0=p_{photon}-p_{\Lambda}$$
    $$p_{photon}=p_{\Lambda}$$
  7. Nov 25, 2014 #6
    I was wondering should use that $$W^2=(\sum E)^2-(\sum p)^2$$
    for both the lab frame of the ##\Sigma## and then the center of mass frame after the decay?
    which gives
    $$(E_{\Sigma^o})^2-(p_{\Sigma^o})^2=(E_{\Lambda}+E_{photon})^2-(p_{\Lambda}-p_{photon})^2$$
  8. Nov 25, 2014 #7
    Im not quite sure what the condition is to give the ##\Lambda## max energy.
  9. Nov 25, 2014 #8
    Orodruin
    Staff Emeritus
    2017 Award
    What does ##(E_{\Sigma^o})^2-(p_{\Sigma^o})^2## evaluate to? What is the relation between the ##\Lambda## and photon energies and momenta?
  10. Nov 25, 2014 #9
    So ##E_{\Sigma}^2-p_{\Sigma}^2=m_{\Sigma}^2##, as for the second question I'm not sure.
  11. Nov 25, 2014 #10
    Orodruin
    Staff Emeritus
    2017 Award
    How about what you just wrote down, but for the ##\Lambda## and for the photon instead?
    Your formula for energy conservation is a bit off and you should correct it.
  12. Nov 25, 2014 #11
    So for the photon and ##\Lambda##
    $$(E_{\Lambda}+E_{photon})^2-(p_{\Lambda}+p_{photon})^2$$
    And the Energy conservation should be ##E_{\Sigma}=E_{\Lambda}+p_{photon}c##
    Right? And expanding the relation before you get;
    $$E_{\Lambda}^2+p_{photon}^2+2E_{\Lambda}p_{photon} - p_{\lambda}^2-p_{photon}^2 -2p_{photon}p_{\Lambda}$$?
  13. Nov 25, 2014 #12
    Orodruin
    Staff Emeritus
    2017 Award
    I suggest starting from just the conservation equations without squaring. The only interesting thing at the moment being: What is the energy of the ##\Lambda## in the rest frame of the decaying ##\Sigma##?
  14. Nov 25, 2014 #13
    So to consider the problem with the entire problem with everything in the rest frame of ##\Sigma^0##?
    In which case if the energy of the ##\Lambda## is;
    $$E_{\Lambda}=E_{\Sigma^0}-E_{photon}$$
    and The momentum would be;
    $$p_{\Sigma^0}=p_{\Lambda}+p_{photon}=0$$
    Therefore;
    $$p_{\Lambda}=-p_{photon}$$
    Which would give;
    $$E_{\Lambda}=E_{\Sigma^0}-p_{photon}=E_{\Sigma^0}+p_{\Lambda}$$
    because photon has E=pc, so;
    $$E_{\Lambda}-p_{\Lambda}=E_{\Sigma}$$
    is that correct?
    And does this mean that the condition for maximum energy is, to consider the ##\Lambda## in the rest frame with the electron travelling in the opposite direction?
  15. Nov 25, 2014 #14
    I just don't understand where the ##2GeV## energy of the ##\Sigma## comes into it if, we are looking at the rest frame because in that frame it has 0 momentum and ##E_{\Sigma}=mc^2##
  16. Nov 25, 2014 #15
    vela
    Staff Emeritus
    Education Advisor
    This equation tells you that the ##\Lambda## and the photon have equal and opposite momenta.
    The signs are probably going to mess you up here. You should keep in mind that momentum is a vector, so it's really ##E_\gamma = \lvert p_\gamma \rvert## for the photon.
    You need to somehow get rid of ##E_\gamma##, ##p_\gamma##, and ##p_\Lambda## because they're all unknowns. You want to solve for ##E_\Lambda## in terms of the masses of the ##\Lambda^0## and ##\Sigma^0##.
    I think you meant photon, not electron. As you found above, conservation of momentum requires that the ##\Lambda^0## and photon go in opposite directions in the rest frame, so no, it's not the condition for maximum energy.
    As Orodruin has suggested, first solve for the energy of the ##\Lambda^0## in the rest frame of the ##\Sigma^0##. This may help give you insight into what the maximum energy condition is.
  17. Nov 26, 2014 #16
    Ah sorry yes I did mean photon not electron.
    So when I'm using the fact that the photon has no mass, it should be [itex]E_{\gamma}=|p_{\gamma}|[/itex] because ##E_{\gamma}^2=p_{\gamma}^2+0^2##, and as you said momentum is a vector so the energy isn't, so the energy is just the magnitude of the momentum vector.
    Thank you both so much for your help, I managed to get the solution after a lot of work.
Have something to add?
Draft saved Draft deleted
