Sakurai 1.27
Suppose that [tex]f\left(A\right)[/tex] is a function of a Hemitian operator A with the property [tex]A|a'\rangle=a'|a'\rangle[/tex]. Evaluate [tex]\langle b''|f\left(A\right)|b'\rangle[/tex] when the transformation matrix from the a' basis to the b' basis is known.
[tex]\langle\beta|A|\alpha\rangle=\int dx' \int dx'' \langle\beta|x'\rangle\langle x'|A|x''\rangle \langle x''|\alpha\rangle=\int dx' \int dx'' \psi_\beta^*\left(x'\right)\langle x'|A|x''\rangle\psi_\alpha\left(x''\right)[/tex]
Transformation from [tex]a'[/tex] to [tex]b'[/tex] basis:
[tex]U|a'\rangle = |b'\rangle[/tex]
Multiply both sides by [tex]a''[/tex]:
[tex]\langle a''|U|a'\rangle = \langle a''|b'\rangle[/tex]
This is the transformation matrix.
Now insert [tex]|a''\rangle\langle a''|[/tex] into [tex]\langle b''|f\left(A\right)|b'\rangle[/tex]:
[tex]\langle b''|f\left(A\right)|a''\rangle\langle a''|b'\rangle[/tex]
Now insert [tex]|a'\rangle\langle a'|[/tex] into the above:
[tex]\langle b''|a'\rangle\langle a'|f\left(A\right)|a''\rangle\langle a''|b'\rangle[/tex]
This is a transformation matrix: [tex]\hat{T}=\langle a''|b'\rangle[/tex]
And so is this: [tex]\hat{T}^*=\langle b''|a'\rangle[/tex].
So then:
[tex]\langle b''|f\left(A\right)|b'\rangle = \hat{T}^* \langle a'|f\left(A\right)|a''\rangle \hat{T}[/tex]
Answers and Replies
gabbagabbahey
No it isn't. In fact, it isn't even a matrix; just an inner product between two states.
What makes you think you are allowed to do this?
Again, not matrices. Also, [itex]\langle a''|b'\rangle^{\dagger}=\langle b'|a''\rangle\neq\langle b''|a'\rangle[/itex]
So then:
If you have [tex]\langle b''|f\left(A\right)|b'\rangle[/tex], why not just insert [tex]\sum_{a'}|a'\rangle\langle a'|[/tex] in there so you can get the eigenvalue of [tex]f(A)[/tex]:
[tex]
\sum_{a'}\langle b''|f(A)|a'\rangle\langle a'|b'\rangle=\sum_{a'}f(a')\langle b''|a'\rangle\langle a'|b'\rangle
[/tex]
Ahhh...I looked at Sakurai a little closer. You're right.
Section 1.5:
"The matrix elements of the U operator are built up of the inner products of old base bras and new base kets."
If Chuck Norris can divide by zero, then I can do that.
[tex]
[/tex]
If
Then
[tex]f\left(A\right)|a'\rangle=f\left(a'\right)|a'\rangle[/tex] ??
I was wondering how that eigenvalue relationship came into play in this problem.
Thanks.
If
Then
Thanks.
Yeah, you can prove this by Taylor expanding some function and then applying the ket, for example the exponential function:
[tex]
\begin{array}{ll}\exp[mA]|a'\rangle&=\left(1+mA+\frac{m^2A^2}{2!}+\cdots\right)|a'\rangle
\\ \,&=|a'\rangle+mA|a'\rangle+\frac{m^2}{2!}A^2|a'\rangle+\cdots
\\ \,&=|a'\rangle+ma'|a'\rangle+\frac{m^2}{2!}(a')^2|a'\rangle+\cdots
\\ \,&=\left(1+ma'+\frac{(ma')^2}{2!}+\cdots\right)|a'\rangle
\\ \,&=\exp[ma']|a'\rangle
[/tex]
So here's what I came up with. Please let me know how it looks:
[tex]\langle b^{(m)}|f\left(A\right)|b^{(n)}\rangle[/tex]
Insert the following:
[tex]\sum_k |a^{(k)}\rangle \langle a^{(k)}|[/tex]
[tex]\sum_l |a^{(l)}\rangle \langle a^{(l)}|[/tex]
[tex]\sum_k \sum_l \langle b^{(m)}|a^{(k)}\rangle \langle a^{(k)}|f\left(A\right)|a^{(l)}\rangle \langle a^{(l)}|b^{(n)}\rangle [/tex]
[tex]=\sum_k \sum_l f\left(a^{(l)}\right) \langle b^{(m)}|a^{(k)}\rangle \langle a^{(k)}|a^{(l)}\rangle \langle a^{(l)}|b^{(n)}\rangle [/tex]
[tex]=\sum_k \sum_l f\left(a^{(l)}\right) \langle b^{(m)}|a^{(k)}\rangle \delta_{kl} \langle a^{(l)}|b^{(n)}\rangle [/tex]
[tex]=\sum_k f\left(a^{(k)}\right) \langle b^{(m)}|a^{(k)}\rangle \langle a^{(k)}|b^{(n)}\rangle [/tex]
[tex]=\sum_k f\left(a^{(k)}\right) \langle a^{(m)}|U^{\dagger}|a^{(k)}\rangle \langle a^{(k)}|U|a^{(n)}\rangle [/tex]
[tex]=f\left(a^{(k)}\right) \langle a^{(m)}|U^{\dagger}U|a^{(n)}\rangle [/tex]
[tex]=f\left(a^{(k)}\right) \langle a^{(m)}|a^{(n)}\rangle [/tex]
[tex]=f\left(a^{(k)}\right) \delta_{nm} [/tex]
It looks like you don't actually need to add [tex]|a^{(k)}\rangle\langle a^{(k)}|[/tex] in the above, but otherwise seems fine to me.
Any ideas on how to do part (b)?
I'm approaching it the same way, with some differences:
[tex]\langle \textbf{p}''|F\left(r\right)|\textbf{p}'\rangle[/tex]
[tex]= \sum_{\textbf{x}'} \sum_{\textbf{x}''}\langle \textbf{p}''|\textbf{x}''\rangle \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle \langle \textbf{x}'|\textbf{p}'\rangle[/tex]
[tex]\langle \textbf{x}'|\textbf{p}' \rangle = \frac{1}{\left(2\pi\hbar\right)^{\frac{3}{2}}}e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}[/tex]
[tex]= \sum_{\textbf{x}'} \sum_{\textbf{x}''}\frac{1}{\left(2\pi\hbar\right)^{\frac{3}{2}}}e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle \frac{1}{\left(2\pi\hbar\right)^{\frac{3}{2}}}e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}[/tex]
[tex]= \frac{1}{\left(2\pi\hbar\right)^{3}} \sum_{\textbf{x}'} \sum_{\textbf{x}''}e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}[/tex]
Now I'm stuck.
I guess those sums should be integrals.
[tex]\frac{1}{\left(2\pi\hbar\right)^{3}} \int \int e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |F\left(r\right)|\textbf{x}'\rangle e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x' d^3x''[/tex]
Does this work here?
[tex]F(r)|\textbf{x}'\rangle = F(x')|\textbf{x}'\rangle[/tex]
If it does, then:
[tex]\frac{1}{\left(2\pi\hbar\right)^{3}} \int \int F\left(x'\right)e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \langle \textbf{x}'' |\textbf{x}'\rangle e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x' d^3x''[/tex]
[tex]=\frac{1}{\left(2\pi\hbar\right)^{3}} \int \int F\left(x'\right)e^{-i \frac{\textbf{p}''\cdot\textbf{x}''}{\hbar}} \delta^3\left(\textbf{x}''-\textbf{x}'\right) e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x' d^3x''[/tex]
[tex]=\frac{1}{\left(2\pi\hbar\right)^{3}} \int F\left(x'\right)e^{-i \frac{\textbf{p}''\cdot\textbf{x}'}{\hbar}} e^{i \frac{\textbf{p}'\cdot\textbf{x}'}{\hbar}}d^3x'[/tex]
[tex]=\frac{1}{\left(2\pi\hbar\right)^{3}} \int F\left(x'\right)e^{-i \frac{\textbf{x}'}{\hbar}\cdot\left(\textbf{p}''-\textbf{p}'\right)}d^3x'[/tex]
while [tex]r=\sqrt{x^2+y^2+z^2}[/tex], you can't make this claim. You'l have to solve this integral as a function of [tex]F(\mathbf{r})[/tex]. Also, an integral is also a sum so
[tex]
\sum_{a'}|a'\rangle\langle a'|=\int|a'\rangle\langle a'|\,da'=1
[/tex]
Basically your last post has it mostly right, though you can't use [tex]F(x')[/tex]. Expanding the integral for spherical coordinates:
[tex]
\langle \mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{1}{\left(2\pi\hbar\right)^3}\int_0^{2\pi}d\phi'\int_{-1}^1d(\cos\theta)\int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}''|\cdot\mathbf{r}}{\hbar}\right]\,dr'
[/tex]
Now I'm stuck.
As before, I don't think you need the double sum. You should just have
[tex]
\begin{array}{ll}\langle \textbf{p}''|F\left(\mathbf{r}\right)|\textbf{p}'\rangle&= \sum_{\textbf{r}'} \langle \textbf{p}''|F\left(\mathbf{r}\right)|\textbf{r}'\rangle \langle \textbf{r}'|\textbf{p}'\rangle
\\ &=\sum_{r'}F(\mathbf{r}')\langle\mathbf{p}''|\mathbf{r}'\rangle\langle\mathbf{r}'|\mathbf{p}'\rangle\end{array}
[/tex]
note the use of [tex]\mathbf{r}[/tex] instead of [tex]\mathbf{x}[/tex] because [tex]F[/tex] is a function of [tex]r[/tex], not [tex]x[/tex].
[tex]
[/tex]
[tex]
[/tex]
Actually, this last line should read
[tex]
\langle \mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{1}{\left(2\pi\hbar\right)^3}\int_0^{2\pi}d\phi\int_{-1}^1d(\cos\theta)\int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}''|r'\cos\theta}{\hbar}\right]\,dr'
[/tex]
I just forgot to remove the vector off of [tex]\mathbf{r}'[/tex], but is otherwise correct as is
Yeah...I made a mistake on this post and since we can't delete them, I'm just erasing it all. You should be fine with what I had written in posts 15 and 16.
When I say [tex]\textbf{x}[/tex], I mean [tex]\textbf{x}=x\hat{\textbf{x}}+y\hat{\textbf{y}}+z\hat{\textbf{z}}[/tex]
And [tex]\textbf{x}'=x'\hat{\textbf{x}}+y'\hat{\textbf{y}}+z'\hat{\textbf{z}}[/tex]
[tex]
[/tex]
So evaluate this:
[tex]\langle\mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{1}{\left(2\pi\hbar\right)^3}\int_0^{2\pi}d\phi\int_{-1}^1d(\cos\theta)\int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}'|r'\cos\theta}{\hbar}\right]\,dr'[/tex]
And get this:
[tex]\langle\mathbf{p}''|F(\mathbf{r})|\mathbf{p}'\rangle=\frac{4\pi}{\left(2\pi\hbar\right)^3} \int_0^\infty (r')^2F(r')\exp\left[\frac{i|\mathbf{p}'-\mathbf{p}'|r'\cos\theta}{\hbar}\right]\,dr'[/tex]
What next? integrate by parts?
Looks like integrating by parts will get rid of the exponential leaving me something in terms of [tex]F(r')[/tex].
So evaluate this:
And get this:
You seem to have forgotten that you have a [tex]\cos\theta[/tex] in your exponential, so you must include that in your integration over [tex]d(\cos\theta)[/tex]. Note, also, that the problem suggests leaving the integral in some form for which you can't integrate any futher without numerical help (ie Mathematica, MATLAB, Maple, etc).
gabbagabbahey
So far, so good:approve:
Are you sure about this?:wink:
Yes, and wouldn't [tex]F(x')[/tex] also have some dependency on [tex]\phi[/tex] and [tex]\theta[/tex], since [tex]x'=r'=\sqrt{x'^2+y'^2+z'^2}[/tex]?
Isn't...
[tex]\sum_k |a^{(k)}\rangle \langle a^{(k)}|=\textbf{1} [/tex]
...the "identity" operator?
gabbagabbahey
Isn't...
Sure, but what you've essentially done is say that
[tex]\sum_k f\left(a^{(k)}\right)|a^{(k)}\rangle \langle a^{(k)}|=f\left(a^{(k)}\right)\sum_k |a^{(k)}\rangle \langle a^{(k)}|=f\left(a^{(k)}\right)[/tex]
How can that possibly be?
Related Threads on Sakurai 1.27
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
