What is the equation for calculating [H3O+] in a salt of weak acid and base?
In summary: When dealing with a weak acid salt and weak base, it is assumed that the three reactions(hydrolysis of BH+,of A-and self water autolysis) depend on each other and there for only one degreeof hydrolysis is used. In reality if the acidity constant of the base is different from that of the basicity ofthe acid the degree of ionization of BH+ is different from that of A-. Assuming that Cs is the initialconcentration of the BHA salt then(BH+)i=(A-)i=Cs. At equilibrium [BH+]=Cs-x or for x=Csα1 then[BH+]=
Salt of weak acid and base
  • Salt
    Votes: 0 0.0%
  • pH
    Votes: 0 0.0%
  • Total voters
Kathe
30
TL;DR Summary
Because of character limit I have exposed my question in the attached pdf
  • Salt of weak acid an weak base(1).pdf
Chemistry news on Phys.org
I wish I could view the file WITHOUT downloading it. I will NOT download the file.
Let me explain: at the beginning I thought I had to insert the post in the "summary" box and it gave me a limit of 250 characters, so I wrote the post in the form of a PDF attachment. I'll rewrite it. Please help me if you can.
In general, when dealing with a weak acid salt and weak base, it is assumed that the three reactions
[BH+]=Cs(1-α1) and [ B]=[H3O+]=x; At equilibrium [A-]=Cs-y or for y=Csα2 then [A-]=Cs(1-α2)
and [HA]=[OH-]=y; If x is different from y how is the pH calculated?Note that Ka. of the base=([ B][H3O+])/[BH+] and Kb of the acid=([HA[OH-])/[A-] where Ka of the acid=Kw/Kb of the acid.Please help me!
Hello Borek, I read the link and I was inspired but I made some changes because in my case [BH +] = Cs- and [A -] = Cs- [HA]. From the charge balance [A -] + [OH-] = [BH +] + [H3O +]. The Ka of BH + is ([H3O +]) / [BH +] = ( [H3O +]) / (Cs- ) and for Cs >> we have that Ka of BH + is equal ad ([H3O +])/ Cs; similarly the Ka of HA is ([A -] [H3O +]) / [HA] = ((Cs- [HA]) [H3O +]) / [HA]; and for Cs >> [HA] we have that Ka of HA is equal to (Cs [H3O +]) / [HA]. So = Ka di BH+ * Cs / [H3O +]; [HA] = (Cs * [H3O +]) / Ka of HA. Always from the charge balance (Cs - [HA]) + Kw / [H3O +] = (Cs - ) + H3O +. Cs - (Cs * [H3O +] / Ka of HA) + Kw / [H3O +] = Cs - (Ka of BH + * Cs / [H3O +]. From which - (Cs * [H3O +] / Ka of HA) + Kw / [H3O +] = - (Ka of BH + * Cs / [H3O +]. Therefore, rearranging (Ka of BH + * Cs / [H3O +] + Kw / [H3O +] = (Cs * [H3O +] / Ka of HA) + [ H3O +]. Applying the logarithms at the end results that 4pH = (pka of BH +) + (pka of HA) + pkw I honestly do not believe that this is the result.
I don't know why it never appears in the post.
[ B] marks the beginning of the bolded text, add a space after the opening square bracket to to avoid that.
Please try to use LaTeX to format your equations (there is a link just below the edit field that explains how to do so):
[tex]K_a = \frac {[H^+][A^-]}{[HA]}[/tex]
I am afraid at the moment your post is unreadable so quite difficult to follow.
Hello, today taking inspiration from you, I went to review the demonstration of the polyprotic acids and I finally succeeded in extracting that [H3O +] = {(Kw + Ka of the base * [BH +]) / (1+ [A -] / Ka acid)} ^ 1/2. If [BH +] ~ Cs and [A-] ~ Cs then [BH +] = [A -] = Cs. Then [H3O +] = {(Kw + Ka of the base *Cs) / (1+ Cs / Ka of the acid)} ^ 1/2. For Ka of the base * Cs >> Kw and Cs / Ka of the acid >> 1 then [H3O +] = {(Ka of the base * Cs) * (Ka of the acid/Cs)} ^ 1/2. So [H3O +] = (Ka of the base * Ka of the acid/Cs)^ 1/2.
1. What is a salt of weak acid and base?
A salt of weak acid and base is a compound that is formed when a weak acid and a weak base react with each other. It is a type of ionic compound that contains both positive and negative ions.
2. How is a salt of weak acid and base formed?
A salt of weak acid and base is formed through a neutralization reaction between a weak acid and a weak base. The acid donates a proton (H+) to the base, forming water, and the remaining ions combine to form the salt.
3. What are some examples of salts of weak acid and base?
Some examples of salts of weak acid and base include sodium acetate (CH3COONa), ammonium chloride (NH4Cl), and potassium carbonate (K2CO3).
4. What are the properties of salts of weak acid and base?
Salts of weak acid and base are typically neutral in pH and have a high solubility in water. They also tend to have a higher melting and boiling point compared to other types of salts.
5. What are the uses of salts of weak acid and base?
Salts of weak acid and base have a variety of uses, including as buffers in chemical reactions, in the production of fertilizers, and in the food industry as preservatives and flavor enhancers.
  • Chemistry
