Same open balls
  • Thread starter bedi
bedi
81
Let M be a metric space with metric [itex]d[/itex], and let [itex]d_{1}[/itex] be the metric defined below. Show that the two metric spaces [itex](M,d)[/itex], [itex](M,d_{1})[/itex] have the same open sets.
[itex]d_1:\frac{d(x,y)}{1+d(x,y)}[/itex]
I tried to show that the neighborhoods around their elements are the same.
An open ball in [itex](M,d): B_{r}(x)=\{y \in R: |x-y|<r\}[/itex]
An open ball in [itex](M,d_{1}): B_{r}(x)=\{y \in R: \frac{|x-y|}{1+|x-y|}<r\}=\{y \in R: (|x-y|)(1-r)<r\}[/itex], let [itex]1-r=n[/itex], hence [itex]n(|x-y|)<r[/itex].
I'm stuck.
Answers and Replies
sammycaps
91
All the open sets in a metric space are arbitrary unions of open balls. So, if you can show that every open ball in (M,d) is the same as some open ball in (M,d1), and vice versa, then you're done.
I think what you could do is take some B(x,r) in (M,d) and find the corresponding B(x,r') in (M,d1), such that they have the same elements.
LCKurtz
Insights Author
774
I'm stuck.
In a metric space, there are generally no absolute values. You have a set ##M##, which may not be the reals and two metrics on ##M##. One is the metric given by ##d(x,y)## and the other, which I will call ##D## is given by $$
D(x,y) = \frac{d(x,y)}{1+d(x,y)}$$Since metrics obey many of the same properties that the absolute value function does on the reals, it may help your intuition to work the problem for ##M## a subset of the reals, but in general, you don't have ##x,y\in \mathbb R## and ##d(x,y)\ne |x-y|##.
bedi
81
Thank you for clarification, am I on the right way though?
Bacle2
Can you show that the open balls in each of the metrics is also open in the other
metric?
bedi
81
As their metrics differ only by a little number n, we can always find a "subball" which is completely surrounded by those open balls?
That was quite sloppy..
Bacle2
I think it would be helpful if you review what LCKurtz said first, to clear things up.
Like he said, in most spaces your distance is not given by an absolute values.
LCKurtz
Insights Author
774
As far as I can tell, I don't think so. Look at Sammycap's suggestion. That leads to an easy solution.
bedi
81
Alright, so let [itex]B_{r}(x)=\{y \in M:d<r\}[/itex] and [itex]B_{r'}(x)=\{y \in M:\frac{d}{1+d}<r\}[/itex] (intuitively [itex]d[/itex] and [itex]1+d[/itex] seem to be positive? Is that correct?)
Then I get the same kind of thing: [itex]B_{r'}(x)=\{y \in M:d\times(1-r')<r'\}[/itex]
Again, multiplying the distance by [itex](1-r')[/itex] doesn't make difference if I choose [itex]r' [/itex]such that [itex]0<r'=r<1[/itex]
Looks like I don't make any progress :(
LCKurtz
Insights Author
774
Intuitively?? Seems to be positive? Isn't ##d## given to be a metric?
At the risk of repeating sammycap's suggestion: Given a ball of radius ##r## in the metric ##d##, what value ##r'## in the metric ##D## corresponds to it? Figure that out. Then show ##B(x,r)## in ##(M,d)## is identical to ##B(x,r')## in ##(M,D)##.
[Edit] Or maybe not. See my next post.
LCKurtz
Insights Author
774
Perhaps I was a little hasty about sammycap's suggestion making the question real easy. Try showing that if d(x,y) is small so is D(x,y), and conversely, and use that to show the metrics are equivalent.
bedi
81
Thank you, I can do it now.
By the way I actually feel guilty for saying that "intuitive" thing.
LCKurtz
Insights Author
774
Don't feel bad. We all, myself included, sometimes type things in haste without taking the time to think it through.
Suggested for: Same open balls
  • Last Post
  • Last Post
