Solving a Physics Problem Involving Two Metal Spheres
In summary, two metal spheres are hanging from the ceiling, one weighing 10g and the other weighing 100g. The 10g sphere falls from a height of 15cm and collides with the stationary 100g sphere. After the collision, the 100g sphere moves at a velocity of 1ms. To calculate the velocity of the 10g sphere after the collision, the equation v = (Uball1(Mball1- Mball2)+2 x Mball2 x Uball2) / Mball1+Mball2 is used, where Uball1 is calculated using Uball1 = sqrt(2x9.81x0.15m). It is assumed that the 10g
Jacques
Hi,
I have a physics problem I need to solve which I think is quite straight forward but would appreciate some input on whether I'm going down the right lines
Tow metal spheres hanging from the roof one of 10g (ball1) and one of 100g (ball2)
ball1 is falling from a height of 15cm accelerating at 9.81ms-2 and collides with sphere b which is stationary
After the collision sphere ball2 is moving at a velocity of 1ms
What is the velocity of ball1?
Now my logic is as follows and I would appreciate comments.
To get the velocity of ball1 we need to use the equation
Now we have everything we need apart from Uball1
Uball1 we need to calculate using
Once I have Uball1 I can calculate the velocity of ball1 after the collision.
Is my thinking correct?
Thanks for your help.
At a quick glance, it looks fine to me. Except for one thing: how should ball 2 start moving when it is hanging on a rope or something and is hit on the top? Or even how can it be hit on the top, while it is obviously connected with the rope on top?
I guess this is a bad case of non-practical assignments.
Sorry, I was unclear on that
both balls are haning from ropes
ball1 is pulled up keeping the string tight to an elevation of 15 cm above ball2
Thanks
j
I have it slightly different.
Conservation of momentum states;
[tex]m_{1}u_{1} = m_{1}v_{1} + m_{2}v_{2}[/tex]
[tex]m_{1}u_{1} - m_{2}v_{2} = m_{1}v_{1}[/tex]
[tex]v_{1} = \frac{m_{1}u_{1} - m_{2}v_{2}}{m_{1}}[/tex]
I think this is different from yours?
~H
Thanks Hoot,
Me again.
In the question above I used a the equation v = sqrt(2as) to get the U of ball1
Is this correct? or should I be using some sort of shm calculation to get the U as the ball is hanging from a rope and thus acting as a pendulum?
thanks
j
As you are not given the length of the rope or any time period of the oscillations, you cannot calculate the velocity if it is undergoing SHM, in addition you are not given a release point. Therefore, I think it as safe to assume that the ball is initially at rest, in which case your formula,[itex]v = \sqrt{2as}[/itex] is correct.
Why do you ask? Has your answer been rejected?
~H
THanks H
Just asking as I was discussing it with someone last night who reconed that its an shm calculation.
the question does however give that the ball1 is pulled up to 15 cm above the height of ballb, this does not give us the length of the rope but can't the 15cm somehow be used as an amplitude in shm?.
My gut feeling is no as we don't know what 15cm is of the total length of the rope.
one las thing: how do you get the mathematical symbols in your posts?
Thanks
j
I think it is safe to assume that the ball was initially stationary. The mathematical symbols use a code called [itex]\LaTeX[/itex]. If you click on any mathematical equations used in these forums a popup will display the code used. There is a tutorial on latex in this thread;
https://www.physicsforums.com/showthread.php?t=8997
Regards,
~H
1. How do you calculate the electric force between two metal spheres?
The electric force between two metal spheres can be calculated using Coulomb's Law, which states that the force is equal to the product of the two charges divided by the square of the distance between them.
2. What information do you need to solve a physics problem involving two metal spheres?
To solve a physics problem involving two metal spheres, you will need to know the charges of the spheres, the distance between them, and any other relevant information such as the dielectric constant of the medium between the spheres.
3. How do you determine the net electric force on a metal sphere in the presence of multiple other spheres?
To determine the net electric force on a metal sphere in the presence of multiple other spheres, you will need to calculate the electric force between each pair of spheres and then add them vectorially.
4. Can the electric force between two metal spheres be negative?
No, the electric force between two metal spheres cannot be negative. It is always a repulsive force, as like charges repel each other.
5. How does the distance between two metal spheres affect the electric force between them?
The electric force between two metal spheres is inversely proportional to the square of the distance between them. This means that as the distance increases, the force decreases, and vice versa.
