Temp of a Comm Satellite in Orbit Around Earth
  • Thread starter MonstersFromTheId
  • Tags
    Orbit Sat
In summary, objects in orbit of Earth experience extreme temperatures, with temperatures reaching up to 300F degrees on the sunny side and close to zero on the shady side. The average temperature at the core of a Comm satellite is similar to Earth's surface temperature, as satellites use thermal systems to regulate their temperature. Without a thermal control system, an object's final temperature in space can range from 4K to the temperature of the Sun, depending on various factors. Overall, temperature in space is not intuitive due to the lack of air and the different ways heat is transferred.
MonstersFromTheId
142
My understanding is that pretty much anything in orbit of Earth is subjected to some, to say the least, "extreme" temperatures. 300F degrees or more above zero on the sunny side, and dammed near as much below zero on the shady side.
So what's the average temp at the core of something like a Comm satellite?
Astronomy news on Phys.org
spin to avg temps?
Temperature in space is very non-intuitive.
Remember, there is no air, and most of the heat we're used to is transferred via conduction from the air which surrounds us.
The only way for a satellite to get hot is through radiation from the Sun or the Earth. The only way for it to get cold is through radiation to the background or the Earth.
Real satellites use complicated thermal systems to pump heat around to radiative panels to get rid of it, so any internal components are more-or-less at Earth surface temperature plus-or-minus about 30 degrees C.
If you just had a block of stuff in space with no thermal control system whatsoever, the final temperature would depend on the absorption and emmission properties of the material, how long the Earth occludes light from the Sun during the object's orbit, geometry and spin rates, etc... so somewhere between 4K and the temperature of the Sun.
1. What is the temperature of a communication satellite in orbit around Earth?
The temperature of a communication satellite in orbit around Earth can vary depending on its location, orientation, and design. On average, the temperature can range from -150°C to 150°C.
2. How does the temperature affect a communication satellite in orbit?
The extreme temperatures in space can have a significant impact on communication satellites. High temperatures can cause components to malfunction and low temperatures can cause materials to become brittle and break. Temperature changes can also affect the satellite's orbit and communication capabilities.
3. How is the temperature of a communication satellite controlled?
Communication satellites have various systems in place to control and manage their temperature. These can include thermal blankets, radiators, and heaters. These systems help to regulate the temperature and prevent any damage to the satellite's components.
4. Can the temperature of a communication satellite in orbit be monitored?
Yes, the temperature of a communication satellite in orbit can be monitored through sensors and thermal imaging technology. These sensors provide real-time data on the satellite's temperature, allowing engineers to make adjustments if needed.
5. How do extreme temperatures affect the lifespan of a communication satellite in orbit?
Extreme temperatures can significantly impact the lifespan of a communication satellite in orbit. High temperatures can cause components to degrade faster, while low temperatures can cause materials to become brittle and break. Proper temperature control and monitoring are crucial for ensuring the longevity of a communication satellite in orbit.
  • Astronomy and Astrophysics
