Satellite and gravitation
  1. Jan 15, 2014 #1
    Hi,
    A satellite with mass m orbits a planet of mass M in a circular path with radius r and velocity v. Due to some internal technical failure, the satellite breaks into two, similar parts with mass m/2 each. In the satellite's frame of reference, it appears the two parts move radially, in opposite directions, along the line connecting the original satellite and the planet's center, each with velocity v0/2. I am expected to show that right after the technical failure, each of the two parts has a total energy equal to -3GM/16r and angular momentum equal to (m/2)√(GMr), wrt the planet's center.
    2. Relevant equations
    3. The attempt at a solution
    The total energy of each of the two parts should be, I believe: Etot = mv02/16 - GmM/(2r). Now, isn't angular momentum preserved despite the failure? However, why isn't the angular momentum zero if the two parts are moving in opposite directions?
  3. Jan 15, 2014 #2
    tiny-tim
    hi peripatein! :smile:
    yes :smile:
    you're misreading the question …
    they are moving in opposite directions in the rest-frame of the satellite
    imagine a rod moving sideways, and two beads moving with equal speeds away from each other along it …
    the actual motions of the beads are both diagonally forwards :wink:
  4. Jan 15, 2014 #3
    The velocity of the the CoM remains v, right? And I know that wrt that CoM, each part moves at +-v0/2, right? Ergo, the velocity of each part wrt to the planet's center should be the sum of the CoM's velocity (which I know) and the velocity of the respective part wrt the CoM (which I also know), correct?
  5. Jan 15, 2014 #4
    tiny-tim
  6. Jan 15, 2014 #5
    Don't I need some sort of relation between v and v0? I am unable to obtain that through conservation of angular momentum though.
  7. Jan 16, 2014 #6
    tiny-tim
    i think vo and v are suposed to be the same
  8. Jan 16, 2014 #7
    haruspex
    No. v is the original tangential velocity. v0 is the radial velocity with which the two move apart.
  9. Jan 16, 2014 #8
    haruspex
    They also have the KE of the original tangential velocity, v.
  10. Jan 16, 2014 #9
    tiny-tim
    i think vo and v are supposed to be the same :smile:
  11. Jan 16, 2014 #10
    haruspex
    Ah, you mean equal, which is not quite the same as same :biggrin:.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Satellite and gravitation
  1. Satellite Gravitation (Replies: 2)
Loading...
