Homework Help: Satellite in orbit
  1. Mar 25, 2017 #1
    Satellite m=3 000kg, circular orbit at the height h = 300km above the Earth´s surface.
    a/ calculate energy ( work ) for delivering satellites into orbit ?
    b/ during 1 month the satellite approached the Earth of Δh=13,8 km. Prove that the radial component of velocity in comparison with the tangential component is insignificant.
    c/ What the average resistance force is applied to the satellite during flight?
    2. Relevant equations
    I know: RE = 6 370 km.....radius of the Earth
    ME = 5,98 .1024 kg...mass of the Earth
    G = 6,67 . 10 -11 Nm2kg-2...gravitational constant
    3. The attempt at a solution
    a/
    W = Ep1 - Ep0
    W = - (G*ME* m) / 2( RE + h) - (- (G*ME* m) / RE
    W = G*ME* m * (( RE+2h)/ 2RE( RE +h))
    with numbers: W = 9,81 . 1010 J
  3. Mar 25, 2017 #2
    gneill
    Staff: Mentor
    Okay. Did you consider the satellite's initial kinetic energy associated with the rotation of the Earth at the time of the satellite launch? Did you have a reason to ignore it?
    You should have listed the equations you used to calculate the energies in the relevant equations section.
  4. Mar 25, 2017 #3
    yes.......
    W = ΔEp + ΔEk
    ΔEk = 1/2 mv2 - 0
  5. Mar 25, 2017 #4
    gneill
    Staff: Mentor
    So the Earth is not rotating?
  6. Mar 25, 2017 #5
    Yes, the Earth moves, but I think -change in kinetic energy can be ignored due to the small mass of the satellite in comparison to the Earth ?
  7. Mar 25, 2017 #6
    gneill
    Staff: Mentor
    Probably something you should verify. What's the KE of the satellite while resting on the Earth's surface? Assume a launch from the equator.
  8. Mar 25, 2017 #7
    a circuit the earth s = 40 000 km
    time......24 hour
    v = s/t = 40 000/24 = 1667 km/hour = 463 m/s
    Ek = 0,5 * 3000 * 4632 = 321,5 MJ
  9. Mar 25, 2017 #8
    gneill
    Staff: Mentor
    Okay. Does that represent a significant contribution to the work done? If not then you are justified in ignoring it.
  10. Mar 25, 2017 #9
    comparison ........ 9,81.107 MJ x 321,5 MJ....yes, I can ignore ΔEk
  11. Mar 25, 2017 #10
    gneill
    Staff: Mentor
    Good!
  12. Mar 25, 2017 #11
    super :-) so it is a/ , but I dont know how prove b/
    radial velocity of the satellite is the centripetal force ?
  13. Mar 25, 2017 #12
    gneill
    Staff: Mentor
    Velocity is not force.
    It's not clear to me what the import is of the Δh. The problem doesn't say whether this is due to the satellite's orbit becoming elliptical or if it remains circular but is shrinking in size over time. Looking at part (c) I'm leaning towards the latter, the orbital radius is shrinking over time due to some frictional force eating away at the KE of the orbit.
    For (b) I suppose you could look at the definition of velocity since you have the radial displacement and the time period over which it occurred.
  14. Mar 25, 2017 #13
    maybe calculate the tangent to the path that the satellite executed for one month ... as a circuit track * time and compare it with the Δh?
    path is circular....h = 300 km, RE = 6 370 km.....radius of the Earth, circumference = 2π( R+h)
    in 1 month....s=t*circumference.......but I dont know t :-( that way probably is not the way :-(
  15. Mar 25, 2017 #14
    v = √G*M/r
  16. Mar 25, 2017 #15
    gneill
    Staff: Mentor
    The satellite's R changed by Δh over one month. What average velocity does that give you?
    What's the satellite's on-orbit velocity?
  17. Mar 25, 2017 #16
    v = √ 6,67.10-11 * 5,98 . 1024 / 6 370 000 + 300 000 = 7739 m/s
  18. Mar 26, 2017 #17
    vector v = vector radial component of velocity vr + vector tangential component of velocity vt
  19. Mar 27, 2017 #18
    What should be the next steps, please?
  20. Mar 27, 2017 #19
    gneill
    Staff: Mentor
    What precisely are you trying to determine?
  21. Mar 27, 2017 #20
    that radial component of the velocity is in proportion to the tangential insignificant...
    can I compare flew a distance s = v*t with Δh?
  22. Mar 27, 2017 #21
    s t = 7739 * 30 * 24 * 3600 = 20 * 109 m = 20*106 km
    20.106 km is disproportionately greater as 13,8 km ?????
  23. Mar 27, 2017 #22
    gneill
    Staff: Mentor
    You want to compare velocities, not distances. You found a tangential velocity in post #16. What you need now is a value for radial velocity.
  24. Mar 27, 2017 #23
    Yes, it is true....
    vR = s/t = 13 800 / 30*24 = 19,6 km/hod ?
  25. Mar 27, 2017 #24
    gneill
    Staff: Mentor
    Be careful with unit conversions. What you've calculated is meters per hour. You'll want to have both the tangential and radial velocities in the same units to make a comparison.
  26. Mar 27, 2017 #25
    yes :-(
    vr = 19,6 km/hod = 70,56 m/s
    vt = 7739 m/s
    the tangential component of the velocity is about 100 times greater than the radial component.......is it right?
Have something to add?
Draft saved Draft deleted
