Schnutz Special Relativity Tensors Question
There's a question in Schnutz - A first course in special relativity
Consider a Velocity Four Vector U , and the tensor P whose components are given by
Pμν = ημν + UμUν .
(a) Show that P is a projection operator that projects an arbitrary vector V into one orthogonal to U . That is, show that the vector V⊥ whose components are
Vα ⊥ = Pα βVβ = (ηα β + UαUβ)Vβ is
(i) orthogonal to U
Now I've attempted the solution and it is the following
PβαVα = Vβ+UβUαVα
So now if I calculate
Vα ⊥ ⋅ U = VαUα+UαUαUαVα
which is orthogonal if c=1 ... as |U|^2= -c^2
but.. this is just in the metric -+++ , if I change metrics to +--- then it won't be orthogonal? Also it's not orthogonal if c=/=1 .. which doesn't seem right to me either
how can that be?
Thank for you help!
Adam
Answers and Replies
robphy
Insights Author
1,621
In general, you should include a factor of ##U\cdot U## in the denominator.
That is to say, you should do the normalization explicitly, in your signature.
Hmmm, how do you mean?
do you mean I need to normalise ##U\cdot U## with itself?
robphy
Insights Author
1,621
[tex]P_{\mu\nu}=\eta_{\mu\nu}- \frac{U_{\mu}U_{\nu}}{\eta_{\alpha\beta}U^{\alpha}U^{\beta}}[/tex]
Thanks for that, but I don't understand why you do this?
robphy
Insights Author
1,621
Does this operator do what you want it to do, independent of signature convention?
Use it and see.
Use it and see.
I think it should, but I can't get it to work out.
The operator is given in the question in the text book.
Orodruin
Staff Emeritus
Insights Author
2021 Award
18,633
8,531
Yes, and the textbook uses all of the conventions which makes the operator a projection operator. If it did not, it would have had to write out the form given in post #4.
Ahhh right I see, that makes sense!
thanks for the help guys
147
Do you mean Schutz, A First Course in General Relativity?
Related Threads on Schnutz Special Relativity Tensors Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
