Schrodinger's Equation: Find E for l=0
In summary, the homework statement is talking about finding the minimum radius for an InAs quantum dot that is embedded in a GaAs matrix in order to ensure that there will be at least one bound electron state. If you choose V = 0.5 eV and effective mass m* = 0.04m, then the separation in the energies between the two bound states tells you about the colour of light the dot would emit when excited.
Nusc
760
[tex]
\frac{1}{r}\frac{d}{dr}(r^2\frac{d}{dr}\Psi (r)) + { \frac{2m}{\hbar^2}[E-V(r)] - \frac{l(l+1)}{r^2}}\Psi (r) = 0
[/tex]
[tex]
V(r) = -Vo r\leq a
[/tex]
[tex]
0 r > a
[/tex]Use
[tex]
\Psi (r) = \Xi (r)/r
[/tex]
Questions asks to Find E l = 0, do I solve the general equation first or should I make l = 0 right away?
It's much easier to set l=0 first.
Inside the dot I get
[tex]
\Xi (r) = C*Cos[l*r]+D*Sin[l*r]
[/tex]
Outside the Dot I get
[tex]
\Xi (r) = A*Exp[-k*r]+B[Exp[k*r]
[/tex]
Taking r to infinity yields:
[tex]
[/tex]What other boundary conditions can I apply?
I took
[tex]
\Xi (a)
[/tex]
and
[tex]
\frac{d\Xi}{dr} [/tex] at r = a
How would I solve these equations?
[tex]
A*Exp[-k*a] = C*Cos[l*a]+D*Sin[l*a]
[/tex]
[tex]
-kAExp[-k*a]=-C*l*Sin[l*a]+D*l*Cos[l*a]
[/tex]
[tex]
\frac{h^2\pi^2}{8ma^2} < E + V < \frac{h^2\pi^2}{2ma^2}[/tex]
Now that's the energy for l=0. how would one want to estimtae the min radius to ensure at least one bound e-state?
NO bound states occur if a^2 < (pi^2 h^2 )/(8*m*Vo)
take positive root.
that's the minimum radius . Is that correct? if not I can't continue.
Now given this:
[tex]
[/tex]
letting V = 0.5 eV and m = 0.04*9.11x10^-31,
how can one find the colour of light in this circle?
what do you mean by: "Inside the dot I get " in post #3
This Boundary condition is good too:
[tex}] \Xi (r=0) = 0 [/tex]
Is the question to find [tex] E{l=0} [/tex]?
What is your "k" in post #3 ?
Is it an atomic physics problem? You are speaking about bound e-states
Take post #6 as a given.
how would one find the minimum radius
This was posted to me via private message T07:54
"question asks, estimate the min radii required of an InAs spherical quantum dot embedded in a GaAs matrix in order to ensure that there will be at least one bound electron state, or at least two bound states in the dot.
Choose V = 0.5 eV and effective mass m* = 0.04m in the dot and barrier layers. Does the separation in the energies between the two bound states tell you about the colour of light the dot would emit when excited?
If not, why not? What else would you need to do in order to obtain this information?
So since I found the bound states.
What do I need to solve for to answer the remaining questions?
I'm not sure about my minimum radius as I posted in the thread, is it correct?"
1. What is Schrodinger's Equation?
Schrodinger's Equation is a fundamental equation in quantum mechanics that describes the behavior of particles at the atomic and subatomic level. It is used to calculate the probability of finding a particle in a specific location at a given time.
2. What does "l=0" mean in Schrodinger's Equation?
In Schrodinger's Equation, "l=0" refers to the angular momentum quantum number, which represents the shape of the electron's orbit around the nucleus. A value of 0 indicates a spherically symmetric orbital, such as the 1s orbital in a hydrogen atom.
3. How is the energy (E) determined in Schrodinger's Equation for l=0?
The energy (E) for l=0 is determined by solving the Schrodinger's Equation with the given value of l. For l=0, the equation simplifies to a single term, making it easier to solve for the energy. The energy value obtained represents the ground state energy level for the particle.
4. What does the solution for Schrodinger's Equation with l=0 represent?
The solution for Schrodinger's Equation with l=0 represents the wave function for the particle in a spherically symmetric orbital. This wave function describes the probability of finding the particle at a specific location in space.
5. How is Schrodinger's Equation used in practical applications?
Schrodinger's Equation is used in many practical applications, such as in the development of new materials, understanding chemical reactions, and designing electronic devices. It is also essential in predicting the behavior of particles in quantum systems, which is crucial for technologies like quantum computing.
