Unlocking the Mystery of the Schroedinger Equation in a Magnetic Field
In summary, the magnetic translations are related to a phase factor which is related to the magnetic flux.
FranzDiCoccio
342
41
Hi all,
there is something I cannot completely understand about the Schroedinger equation for a charged particle in a constant magnetic field.
I think I get most of it, hopefully, but there is something I still am unable to fit into place.
So we know that when a magnetic field is present the Hamiltonian becomes
[tex]H = \frac{{\mathbf P}^2 }{2 m}, \qquad {\mathbf P} = {\mathbf p} - \frac{q}{c}{\mathbf A}[/tex]
where q is the charge of the particle and A is the magnetic vector potential, such that [tex]\nabla \times {\mathbf A} = {\mathbf B}[/tex].
Of course when the magnetic field is constant (say, along the z direction), the system is translationally invariant, but this can be made tricky by the gauge. Let me choose the "symmetric gauge" [tex]A_x = -B y /2[/tex], [tex]A_y = B x /2[/tex], so that the components of the kinetic momentum become
[tex]P_x = p_x +\alpha y,\qquad P_y = p_y -\alpha x,\qquad \alpha = \frac{q B}{ 2c}[/tex]
My question is about the generators of the translations. As far as I can understand,
these operator are deceptively similar to the above components of the momentum. They
are
[tex]T_x = (p_x -\alpha y) = \alpha Y ,\qquad T_y = (p_y +\alpha x) = \alpha X[/tex]
where [tex](X,Y)[/tex] is the quantum analog of the center of the classical cyclotron motion.
Now, I see that these commute with the components of P, and therefore with the Hamiltonian. Hence they must be related to some kind of symmetry.
I also see that this symmetry is translational invariance, in a way. I mean, I can sort of derive them through the Noether's theorem from the (classical?) Lagrangian.
On the other hand, it seems to me that their action on a generic wavefunction is not a "simple" translation. There is also a phase factor dependent on the magnitude of the translation.
What's the point here? One should not be so fussy and call such a transformation a translation anyway, because the phase factor does not show up in a measurement?
Or is it a more tricky point, related to gauge fixing?
I'd say the second, but I'm not able to fit things into place...
I came up with this "picture", but I'm not sure about it...
As I mention, acting with [tex]T_x[/tex] on the wavefunction brings about a phase factor
[tex]\exp\left(i \frac{x_0}{\hbar} T_x \right)\psi(x,y) = \exp\left(-i \frac{x_0}{\hbar} \alpha y \right) \exp\left(i \frac{x_0}{\hbar} p_x \right)\psi(x,y) = \exp\left(-i \frac{q B}{2 \hbar c} x_0 y \right) \psi(x+x_0,y) = \exp\left(-i \frac{q \varphi}{\hbar c} \right) \psi(x+x_0,y)[/tex]
Such phase factor is the same corresponding to a gauge transformation of the vector potential:
[tex]{\mathbf A}(x,y) \mapsto {\mathbf A}(x,y) -\vec \nabla \varphi = {\mathbf A}(x,y)-\frac{B}{2} x_0 \hat e_y = {\mathbf A}(x-x_0,y)[/tex]
i.e. the translation opposite to that we're considering, applied to the vector potential...
This seems to figure... However I'm not very sure about it...
Thanks for any insight you can provide
Franz
PS I've corrected a wrong (I think) sign in the last equation.
The first thing that comes to mind is that the vector potential causes the presence of a curvature, which is the magnetic field. When a particles moves through a curved background it picks up a phase term, known as Berry's phase. My guess is that the phase you pick up through these translational operators is precisely this Berry phase.
Note that this is not just a minor phase factor which you can ignore. The terms causes the translational operator in the x and y-direction to no longer commute. In fact, Tx and Ty satisfy what is known as the magnetic translation algebra which has some interesting features.
Hi xepma,
and thanks for replying. Yes, I understand that all of the things you mention are related to my question. In fact, I stumbled on those translation operators in an algebraic proof that the magnetic flux must be quantized. But now I'm under the impression that I have misunderstood the sketch of the proof that a friend gave me.
I'll look for more information on "magnetic translations". Anyway the adjective "magnetic" somewhat satisfies me, because at least it warns you that there's more to them than the usual translations.
Thanks again
F
Thanks again
F
It becomes even more complicated when you consider more electrons in a magnetic field! You would need to fix (i.e., minimize) some constant terms in each A for each electron in order to obtain the global minimum of the quantum many-electron system.
Hi F,
I did some more browsing and thinking and I found just a little more on the subject.
Note that the Hamiltonian is given by
[itex]H = \frac{1}{2m}\left(p-e A)\right)^2[/itex]
On the classical level the system is translational invariant, but on the quantum level we work with the vector potential. Hence, the system is no longer translational invariant when we introduce a gauge which is not translational invariant (like the symmetric gauge). To be more precise: the normal translational operators, x and y, do not commute with this Hamiltonian.
On the other hand, like you showed, the magnetic translational operators are more of use here. Specifically, these operators do commute with the Hamiltonian. But unlike normal translational operators, the action on the wavefunction also induces a phase factor. But apart from what I said earlier, I'm still not completely sure what else this implies...
Actually, the magnetic translation operator translates the guiding center(=center of the cyclotron motion).
Yes, I agree with that. They are translation operators, after all.
My comment was just meant to emphasize that if you take the classical center of the cyclotron motion (X,Y) and substitute classical position and velocity (or better, kinetic momentum) with their quantum versions you get the above operators (up to a multiplicative constant).
xepma said:
Hi F,
Hi xepma,
and thanks for the feedback. I'm not sure I agree with you that the classical hamiltonian is manifestly translationally invariant, though. It seems to me that you get the "gauge problem" also at the classical level. At a first glance I'd say that classically it is not a big deal because because the gauge transformation that you need for reabsorbing the extra term does not call for a "weird" phase factor.
Anyway, I have just found a book on the quantum Hall effect featuring an appendix on the magnetic translation operators. I hope it will clarify my doubts which, at the moment, I'm not even able to state clearly any more.
Thanks again
F
Hi F,
Yea, my statement referring to the classical <-> quantum level might not be the best one.
Anyways, if you find something new and you want to discuss it, feel free to state it here. I'm also quite interested in the matter. Formulating the proper questions is always one of the bigger difficulties with these sort of things ;)
You are right. It isn't hard to verify it. (Note that X and Y are canonically conjugate variables. Try to evaluate the commutator [X,Y])
1. What is the Schrödinger equation?
The Schrödinger equation is a fundamental equation in quantum mechanics that describes how the wave function of a physical system evolves over time. It is named after Austrian physicist Erwin Schrödinger and is used to study the behavior of particles on a microscopic scale.
2. How does a magnetic field affect the Schrödinger equation?
A magnetic field introduces an additional term in the Schrödinger equation, known as the vector potential. This term takes into account the interaction between the magnetic field and the particle's spin, and it affects the behavior of the wave function in the presence of a magnetic field.
3. What is the significance of studying the Schrödinger equation in a magnetic field?
Studying the Schrödinger equation in a magnetic field allows us to understand the behavior of particles in a magnetic field, which has many practical applications. For example, it is crucial for the development of technologies such as magnetic resonance imaging (MRI) and magnetic data storage.
4. What are some challenges in unlocking the mystery of the Schrödinger equation in a magnetic field?
One of the main challenges is the complexity of the Schrödinger equation in a magnetic field, which makes it difficult to solve analytically. This requires the use of advanced mathematical techniques and computational methods to obtain solutions. Additionally, there are still many unanswered questions and areas of research in this field.
5. How does understanding the Schrödinger equation in a magnetic field contribute to our understanding of the universe?
Studying the Schrödinger equation in a magnetic field is essential in our understanding of the fundamental laws of nature at a microscopic level. It allows us to better understand the behavior of particles in different environments and provides insights into the behavior of matter in the universe, such as the formation of stars and galaxies.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
