Schrödinger Eq: Questions on Mass, Uncertainty & Pi
In summary: I'm afraid.In summary, the equation describes a wave function not a particle, and mass is not subject to Heisenberg's uncertainty principle. The Schrödinger equation has pi in it, but it's just a representation of real numbers and has a limit.
Sruli
Some questions on Schrödingers equation (se)...
1) what does the m in se refer too the equation describes a wave function not a particle so how can we associate a mass with it.
2) the equation has to have fixed numbers ie it can't have any numbers with uncertainies yet shouldn't mass be subject to Heisenberg's uncertainty principle??
3) this applies to other physics as well...it has pi in the equation yet pi goes on for ever how does it make sense to assign a number that goes on for ever to a physical quantity as surely that must have a limit?
Hi and welcome to PF!
1) I'm not comfortable discussing the math yet, as I'm more of a concept kind of guy. Perhaps someone else can help with that...
2) You might be surprised what tricks you can do with the math, but that has nothing to do with Heisenberg's uncertainty principle. That merely states that you can only accurately MEASURE a particle's position but the momentum will be uncertain, or accurately MEASURE a particle's momentum and the position will be uncertain.
3) You only need to be as precise as required for your purpose. If all you want to do is get an estimate of the circumference of a circle of 1m diameter, 3.14 is fine, if however you want to get the circumference of the observable universe in meters, and all you have is the diameter, you would certainly need several more decimal places to get a reasonable result.
Sorry I meant the energy time uncertainty relation and if you don't measure the mass how do you know what to put in the equation
The time-energy uncertainty? What else would you use for mass?
Well, the deeper answer is that it's really associated with a "representation of the Galilei group of transformations" (I'm restricting to the nonrelativistic case here). See, e.g., Wiki Galilean transformation, and possibly its representation theory.
But from your questions, I suspect these references might be too advanced. The Galilean transformations correspond to the familiar motions you can perform in space and time, i.e., rotation, displacement, velocity boost, etc. For such a group of transformations, there are quantities called "Casimir operators", which remain unchanged under these transformations. Mass is one of the Casimirs of the Galilean group -- it doesn't change under any of these transformations. The idea in QM is to represent these transformations as operators on an (abstract) Hilbert space of wave functions. The Hilbert space for wave functions corresponding to mass=##m_1##, say, is distinct from the Hilbert space wave functions corresponding to mass=##m_2## (where ##m_1 \ne m_2##). The Schrodinger equation is just an expression of how time evolution proceeds when represented in terms of such wave functions and the Hilbert space containing them.
I'd normally recommend Ballentine's QM textbook for this sort of question, but perhaps a more elementary text is needed here. Others may have suggestions.
Quantum uncertainties are associated with noncommuting operators. E.g., for the Galilean case, the operators corresponding to position and momentum do not commute, and hence lead to a position-momentum uncertainty principle. But mass commutes with all the operators in the Galilei group, hence we don't get such an uncertainty principle involving mass.
OK, I guess you haven't yet studied the mathematical concept of real numbers? They're well understood mathematically, and thousands of people use them every day all over the world. As for comparing any predictions arising from the SE with experiment, well sure, all real-world experiments are necessarily of finite accuracy. So the theoretical predictions (which may indeed involve a non-terminating real number) need only be compared with experimental results up to the level of accuracy possible with that experiment's equipment.
As for time-energy uncertainty, that gets trickier since one must use the Poincare group instead of the Galilei group to analyze the relativistic case. But mass (i.e., invariant mass in the sense of special relativity) is still a Casimir of the Poincare group.
HTH.
Likes bhobba
The wave function is used for calculating the probbility of detecting a particle at various locations. We use the mass of that particle, e.g. the mass of the electron if we're talking about the SE for the electron in a hydrogen atom.
Just to elaborate on Strangerep's excellent explanation, which is the correct, although unfortunately advanced, answer; it turns out if you chug through the math you end up with a quantum equation p = Mv where M is some constant and v is the quantum mechanical velocity observable. This looks strikingly like the definition of momentum in classical physics. You can in fact make it the same by introducing a change of units so m = hbar M - where hbar is a constant that simply changes units and m the mass. Hence you end up with hbar p = mv. This means hbar p is the analogue of classical momentum. hbar, called the reduced plank constant, is h/2pi where h is Planks constant. Planks constant is simply something that allows us to work in out usual units. Its nothing deep and mysterious like some accounts suggest.
Thanks
Bill
What is the Schrödinger equation?
The Schrödinger equation is a fundamental equation in quantum mechanics that describes how the state of a quantum system changes over time. It is named after Austrian physicist Erwin Schrödinger and is a key tool for understanding the behavior of particles on a microscopic scale.
What is the relationship between mass and the Schrödinger equation?
The Schrödinger equation takes into account the mass of a quantum system, as it is based on the principle of wave-particle duality. This means that particles, such as electrons, can exhibit both wave-like and particle-like properties. The mass of a particle is important in determining its behavior according to the Schrödinger equation.
How does the Schrödinger equation incorporate uncertainty?
The Schrödinger equation includes the concept of uncertainty through the use of probability. Instead of predicting the exact position and momentum of a particle, the equation provides a probabilistic distribution of these properties. This is because, on a quantum scale, it is impossible to know the exact state of a particle at any given time.
What role does Planck's constant play in the Schrödinger equation?
Planck's constant, denoted by h, is a fundamental constant in quantum mechanics and is used in the Schrödinger equation to determine the energy of a quantum system. It relates the frequency and energy of a particle and is essential in understanding the behavior of particles on a microscopic scale.
Why is the irrational number pi used in the Schrödinger equation?
The number pi (π) is used in the Schrödinger equation because it appears in the mathematical representation of the wave function, which is a key concept in quantum mechanics. The wave function describes the probability of finding a particle in a certain state and its mathematical form involves the use of pi.
