Homework Help: Scoring blackjack in c++
  1. Dec 31, 2012 #1
    I am writing a program in c++ where it inputs card values from the user and stores it in a char type variable. valid inputs are numbers 1-9, t,k,q,j for ten, kind, queen, jack respectively and a for ace. after inputting all the values the program goes like this
    Code (Text):
    if (!(card1 == 'a'))
            switch (card1)
            case '1':
                score = score + 1;
                break;
            case '2':
                score = score + 2;
                break;
            case '3':
                score = score + 3;
                break;
            case '4':
                score = score +4;
                break;
            case '5':
                score = score + 5;
                break;
            case '6':
                score = score + 6;
                break;
            case '7':
                score = score + 7;
                break;
            case '8':
                score = score + 8;
                break;
            case '9':
                score = score + 9;
                break;
            case 't':
            case 'j':
            case 'k':
            case 'q':
                score = score + 10;
                break;
            default:
                break;
    the code is the same for card 2,3,4, and 5. The problem I am having is that I don't know how to deal with aces. if there is only one ace I can simply go like this
    Code (Text):
    if (card1 == 'a' || card2 == 'a' || card3 == 'a' || card 4 == 'a' || card5 = 'a')
          if (21-score <= 11)
                  score = score + 11;
           else
                   score = score +1;
    but what if there are multiple aces? then I have to decide which ace counts as 1 and which 11. I can do that by reiterating the above statement. but I don't know how to find out how many aces I have aside from using brute force where I list 20 cases for every combination of cards that might end up being aces.
    On a side note I have never played blackjack before so I am just going by the brief description of the game given in the question. Also this is my first time using switch statement so I don't know I did used it right.
  3. Dec 31, 2012 #2
    I like Serena
    Hi wahaj! :smile:
    Why don't you count each ace as 1 point?
    But do keep track if you have at least one ace.
    At the end, if the score is 11 or lower, and you have at least one ace, add 10 points.
    Your switch statement is fine.
    However, duplicating it 5 times is bad programming practice.
  4. Dec 31, 2012 #3
    hmm that might work. Also do you by any chance have a better solution to the switch statements. After all no body wants to read 300 lines of switch statements.
  5. Dec 31, 2012 #4
    I like Serena
    Put the cards in an array, and use a for-loop to iterate over them.
    Then you can use card in the switch-statement.
  6. Dec 31, 2012 #5
    Right, except arrays are still 3 chapters away . I probably should have mentioned that I only know loops and if else statements and variables so far. Thanks anyways.
  7. Dec 31, 2012 #6
    I like Serena
    Ah, I guess it's a little early to talk about good programming practices then.
    Good luck!
