Would the Induced Current Change Direction Inside a Solenoid with a Search Coil?
In summary, the speaker is asking if the induced current in a search coil inserted inside a solenoid, with the plane of the coil perpendicular to the magnetic field, would change direction in the middle of the solenoid. They clarify that the solenoid has a current running through it and is creating a magnetic field similar to a bar magnet. They then ask how the emf (electromotive force) would vary as the coil is moved through the solenoid, assuming the magnetic field inside is uniform.
apache
if we were to insert a search coil inside a solenoid, (plane of coil perpendicular to B), would the induced current change direction in the middle of the solenoid ? it would have to wouldn't it since it would now be approching the opposite pole ---
What exactly do you mean? Can you be more specific here? What is search coil? Induced currents where? In the middle of solenoid? There is no current in the middle of solenoid.
sorry for the delay,
what i am trying to ask is basically this;
imagine a solenoid , with a current running through, creating a magnetic field basically like that of a bar magnet.
now if we were to take another coil( a smaller one) and move that coil through the solenoid, how would emf vary throughout that motion.
would it increase gradually as the coil cam closer to the solenoid and then hold a constant value whilst it is inside and then slowly taper off one it is out the other side of the solenoid. i am assuming this since the magnetic field inside the solenoid is uniform ...
thanks
-apache
1. What is the purpose of a search coil inside a solenoid?
The search coil inside a solenoid is used to detect any changes in magnetic field strength. It can also be used to measure the strength and direction of a magnetic field.
2. How does a search coil inside a solenoid work?
A search coil is a loop of wire that is connected to an electrical circuit. When the coil is placed inside a solenoid, any changes in the magnetic field will induce a current in the coil, which can be measured by the circuit. This current can then be used to determine the strength and direction of the magnetic field.
3. Can a search coil inside a solenoid be used to detect non-magnetic objects?
Yes, a search coil inside a solenoid can be used to detect non-magnetic objects as long as they are conductive. This is because the coil measures changes in current, which can be induced by any conductive material.
4. What are the advantages of using a search coil inside a solenoid?
One advantage is that it can detect very small changes in magnetic field strength, making it useful for sensitive measurements. Another advantage is that it is a non-invasive method, meaning it does not physically touch the object being measured.
5. Are there any limitations to using a search coil inside a solenoid?
One limitation is that it can only detect changes in magnetic field strength, and not the absolute value. Additionally, the size and shape of the coil can affect its sensitivity and accuracy.
  • Electrical Engineering
  • Classical Physics
  • Classical Physics
  • Electromagnetism
