supernova1203
- 210
cos = 5/5.38
so
secant is = 5.38/5?
thats my solution anyway, just want to check if i got it right.
so
secant is = 5.38/5?
Verifying secant is 5.38/5 means to confirm that the value of the secant function at a given angle is equal to 5.38/5.
Secant is calculated by taking the reciprocal of the cosine function, so secant = 1/cosine.
Secant is an important trigonometric function that is used to solve problems involving right triangles and circular motion. It is also used in the derivation of other trigonometric identities.
The range of values for secant is all real numbers except for -1 and 1, as these values would result in a division by zero error.
To verify secant is 5.38/5 using a calculator, you can enter the angle in degrees or radians and then use the reciprocal button (usually denoted by "1/x" or "x^-1") to find the secant value. Make sure your calculator is in the correct mode (degrees or radians) before performing the calculation.
