Second Measurement of Spin
  • Thread starter gametheory
gametheory
So in my quantum class we learned that if you measure spin in one direction and get h/2 and then in another direction that it will be (plus or minus)h/2 as well. I was wondering how you would know the probability of it being the positive value vs the negative value. It's a function of the angle between the two directions, right?
Answers and Replies
Faradave
108
I'm just a beginner myself, so wait for other replies. I've found that if spin is measured along a given axis of a spin½ particle, then the probability (p) that spin then measured along another axis will have the same sign (+ or -) is:
p = cos(α)/2 + 50%,
where α is the angle the new axis makes with the original axis.
Good luck!
gametheory
That looks like it works. Do you know where this comes from? I figured it involves the pauli matrices in each of two orthogonal directions acting on the possible wavefunctions, but I wasn't sure how to arrange that into an equation.
dipstik
126
you want to look at stern-gerlach experiment i think. should be some good reading.
Bill_K
Insights Author
4,157
203
Under a finite rotation, angular momentum states transform into each other with the aid of a unitary matrix. Naturally this matrix is called the rotation matrix, and written d(j)mm'(β) = (j m'|exp(iβ/ħ Jy)|j m) where β is the angle. For j = 1/2, d(j)mm'(β) = [tex]\left(\begin{array}{cc}cos(β/2) &sin(β/2)\\- sin(β/2)&cos(β/2)\end{array}\right)[/tex] Thus, if you have a state with Jz = +1/2 and describe it in terms of the spin states quantized along an axis inclined at an angle β to the z axis, the probability amplitude of finding Jβ = +1/2 is cos(β/2) and the probability amplitude of finding Jβ = -1/2 is sin(β/2).
Faradave
108
I'm afraid I made mine up from a table of some spin correlations.
DrChinese
1,543
I think that:
Cos^2(theta/2) = Cos(theta)/2 + .5
Where theta = {0, 45, 60, 90 degrees} that looks pretty good. :smile:
Faradave
108
Interesting! My daughter's old precalculus book lists the "Double Angle Formulas":
cos = 2cos2θ -1 = 1 - 2sin2θ = cos2θ - sin2θ, also
sin = 2sinθcosθ
This raised a follow-up question, if I may. (I'll start a new thread if needed.)
Over what range of angles is the quantum spin correlation formula considered complete?
The table I had listed five spin correlations from 0° to 180°. Classical trigonometry addresses 360° in its unit circle. But it seems that quantum spin is associated with a 720° rotation, at least for fermions.
Suggested for: Second Measurement of Spin
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
