Homework Help: Second order differential
  1. Nov 28, 2008 #1
    I've completed this question but I dont think i've got it right. It's from a 2008 June FP1 further maths paper. There is a second part to the question I dont understand which I will post after I know I have got this part right :)
    Find, in terms of k, the general solution of the differential equation:
    [tex]\frac{d^{2}x}{dt} + 4 \frac{dx}{dt} + 3x = kt + 5[/tex]
    3. The attempt at a solution
    First of all i created auxilary equation
    [tex]T^{2} + 4T + 3[/tex]
    and solved it to get 2 real roots, 3 and 1
    2 real roots imply that the complementory soltuion:
    is [tex]y = Ae^{çx} + Be^{ßx}[/tex]
    i can fill in ç and ß, as it's the roots from the auxilary equation
    [tex]y = Ae^{x} + Be^{3x}[/tex]
    Now I do need use inspection to find the particular soltution:
    let x = at + b
    [tex]\frac{d^{2}x}{dt} = 0 \frac{dx}{dt} = a[/tex]
    try:
    [tex] 0 + 4(a) + 3(at +b) \eqiv kt + 5[/tex]
    compare coefficients
    so 3a = k
    4a + 3b = 5
    a = k/3
    b = (15-4k)/3
    so the general solution is:
    [tex]y = \frac{k}{3} e^{x} + \frac{15-4k}{3} e^{3x}[/tex]
    is that right :) ?!
    Cheers :)
  3. Nov 28, 2008 #2
    tiny-tim
    erm … -3 and -1 :redface:
  4. Nov 28, 2008 #3
    Sorry im being an idiot. I used comleting the square and by habbity i did
    (T-2)²
    when it should be +
    so is the final answer:
    [tex]
    y = \frac{k}{3} e^{-x} + \frac{15-4k}{3} e^{-3x}
    [/tex]
  5. Nov 28, 2008 #4
    tiny-tim
    No! Try again.
    No, the particular solution is added to the general solution.
  6. Nov 28, 2008 #5
    so where does the complimentry solution come in?
  7. Nov 28, 2008 #6
    tiny-tim
    oh … i meant complementary … i couldn't remember the word :redface:
    … the particular solution is added to the complementary solution.
  8. Nov 28, 2008 #7
    aha, cool.
    so
    [tex]
    [/tex]
    a = k/3
    b = (15-4k)/3
    is that it? How do I find the values of A and B
  9. Nov 28, 2008 #8
    tiny-tim
    You don't need to :biggrin:
    the general solution does have two unknown constants.
  10. Nov 30, 2008 #9
    so is my final answer:
    [tex]
    y = Ae^{x} + Be^{3x} + \frac{k}{3} + \frac{15-4k}{3}
    [/tex]
  11. Nov 30, 2008 #10
    tiny-tim
    No …
    see your post #3 …
    and i don't think the fractions are right either …
    please get into the habit of plugging your solution back into the original equation, to see if it works! :wink:
    (if it doesn't, then its wrong! :rolleyes:)
  12. Nov 30, 2008 #11
    Mark44
    Staff: Mentor
    No, your values for a and b, the coefficient of t and the constant, are wrong. They should be: a = k/3, b = 5/3 - 4k/9. And you forgot that the coefficients of x in the exponential terms are negative. (I have reverted to the variables of the original problem, x and t.)
    [Answer Removed]
    The homogeneous solution (aka complementary solution), [tex]x_h(t)[/tex] is the part of the general solution for which x''(t) + 4x'(t) + 3x(t) = 0. The particular solution is the part of the general solution for which x''(t) + 4x'(t) + 3x(t) = kt + 5.
    One thing about differential equations: getting the solutions takes a bit of doing, but if you know how to differentiate, you can check that your answer actually is a solution by verifying that the appropriate combination of x''(t), x'(t), and x(t) actually add up to what they're supposed to.
  13. Nov 30, 2008 #12
    Mark44
    Staff: Mentor
    BTW, for future reference, differential equations are NOT precalculus!
  14. Nov 30, 2008 #13
    tiny-tim
    Hey Mark …
    no complete solutions, please!
    could you edit? :smile:
