Second Order ODE Homogenous
(Reduction of order) The function y1 = x-1/2cosx is one solution to the differential equation x2y" + xy' + (x2 - 1/4) = 0. Use the method of reduction of order to find another linearly independent solution.
I divided x2 to both sides to get the equation into y" + py' + qy = 0
y" + (1/x)y' + ((1 - (1/4x2)) = 0
Using Abel's method
c e-∫(p)dx
= c e-ln x
y2 = -c lnx[/B]
Am I doing this right?
Answers and Replies
SteamKing
Staff Emeritus
12,796
1,670
Using Abel's method
c e-∫(p)dx
= c e-ln x
y2 = -c lnx[/B]
Take y2 and plug it back into the original differential equation and see if it is satisfied. :wink:
vela
Staff Emeritus
Education Advisor
15,038
1,610
Using Abel's method
c e-∫(p)dx
= c e-ln x
y2 = -c lnx[/B]
No, the problem said to use the method of reduction of order.
But first, did you type the differential equation and solution correctly? I ask because the supposed solution doesn't satisfy the given differential equation.
HallsofIvy
41,833
964
You mean x2y" + xy' + (x2 - 1/4)y = 0, don't you? As Vela pointed out, the given y1 does not satisfy the equation you gave. Perhaps it satisfies this one. I haven't checked.
So you start by looking for a solution of the form [itex]y_2= u(x)x^{1/2}cos(x)[/itex]
Find the first and second derivatives of that and put them into the equation. If your given function really is a solution to the differential equation, then all terms involving only "u" (as opposed to u' or u'') will cancel leaving a first order equation for v= u'.
3. The Attempt at a Solution
Using Abel's method
c e-∫(p)dx
= c e-ln x
y2 = -c lnx
Using Abel's method
c e-∫(p)dx
= c e-ln x
y2 = -c lnx[/B]
Related Threads on Second Order ODE Homogenous
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
