See this
  1. Dec 3, 2005 #1
    {if n is the sum of the first a natural numbers then it is a triangular number}eg 6=1+2+3
    {a is any integer }show that m!+1is a perfect square if and only if m!/8 is a triangular number.m!/8 is a triangular number.so m!=o(mod8) therefore m has to be minimum 4 and not a multiple of 3.
  3. Dec 3, 2005 #2
    HallsofIvy
    The factorial doesn't have much to do with it.
    The nth triangular number is n(n+1)/2 so if k/8 is triangular number, then k= 4n(n+1) for some n. k+ 1= 4n(n+1)+ 1= 4(n2+ n)+1= 4n2+ 4n+ 1= (2n+ 1)2, a perfect square.
    Conversely, if k+ 1 is a perfect square then k+1= n2, k= n2- 1 so k/8= (n2- 1)/8= (n-1)(n+1)/8= ((n-1)/2)((n+1)/2)/2= m(m+1)/2 with m= (n-1)/2. That will be a triangular number as long as m is an integer: as long as n-1 is even which means n itself and so n2 must be odd. That is true if and only if k is even- certainly every factorial larger than 1 is even- that's the only place the "factorial" is required.
    In fact: If k/8 is a triangular number then k+1 is a perfect square
    and if k is an even number, larger than 7, such that k+1 is a perfect square, then k/8 is a triangular number.
  4. Dec 3, 2005 #3
    4! +1 is a square, 5! +1 is a square and 7!+1 are squares, but 6! + 1 is not a square. Your response answers the question of why 4!/8, 5!/8 and 7!/8 are triangular numbers. But I see a deeper question since the poster states that m can not be divisible by three if m! + 1 is a square. To me the meat of the post is to prove or disprove that m! + 1 can not be a square if m is divisible by 3, and to possibly show if there are any other values of m for which m! + 1 is a square although I admit that issue was not actually put forth in the post.
  5. Dec 4, 2005 #4
    sorry
    sorry i forgot mention that this how i worked .the question is to prove m!+1 is a perfect square if m is triangular.
  6. Dec 4, 2005 #5
    HallsofIvy
    That's not at all what you originally posted and is not true!
    The first 5 triangular numbers are 1, 3, 6, 10, 15.
    If m= 1, then m!+ 1= 2 which is not a perfect square.
    If m= 3, then m!+ 1= 7 which is not a perfect square.
    If m= 6, then m!+ 1= 721 which is not a perfect square.
    If m= 10, then m!+ 1= 3628801 which is not a perfect square.
    If m= 15, then m!+ 1= 1307674368001 which is not a perfect square.
    What IS the question??
  7. Dec 5, 2005 #6
    I had worked on this question.i thought that m! is perfectly divisible by 8because m!/8 is a trianguar no.for m! to be a multiple of 8 it has to be >or=4.but m cannot be a multiple of 3 .as u had proved m!+1is not a perfect square. in the question no such condition is provided .so how u prove it .
  8. Dec 5, 2005 #7
    Please proof read to make sure your points are clear. Your previous post confused m! with m!/8 as noted by HallsofIvy. In this post, I have problems understanding what is meant by "but m cannot be ... as u had proved m!+1is not a perfect square". Why is that so? Who proved it? All I see is that m! + 1 is not square for m = 3,6,9,12 and 15; but that does not prove that m can't be some higher multiple of 3 for m! + 1 to be square.
    P.S. Earlier I commented on your statement in the original post: "{a is any integer }show that m!+1is a perfect square if and only if m!/8 is a triangular number.m!/8 is a triangular number.so m!=o(mod8) therefore m has to be minimum 4 and not a multiple of 3." stated that m can not be a multiple of 3. How did come up with this? Was this in error also or did want a proof of it?
  9. Dec 5, 2005 #8
    see: 6!+1 is not a perfect and similarly for all other multiples of 3 . it is found that 3,6,9,12,15.. are not the values that m can take .see by substituting the values in m!+1.but no condition is mentioned in the sum.so u have to prove that this condition has to be imposed on m.and u are given m! is perfectly divisible by 8.but only when m is>or= 4.other wise m! will not be a multpile of 8. so how u prove that if m is a multiple of 3; m is not a triangular no..i did not prove that m!+1is not a perfect square for multiples of 3.i just saw by substituting the values.
  10. Dec 6, 2005 #9
    If you had any savvy in math, you would never say positively that something is true for all multiples of 3 merely because it is true for all multiples of 3 that you had checked. Mathematicians don't do this unless they have knowedge of a proof. The fact that you found it true for all values that you try is merely a hint of its validity, and you might make a "conjecture" or "proposition" that it is true for all values as it has not yet been proven so. But there is a big difference in stating that "m has to be ... and not a multiple of 3" or that "but m cannot be a multiple of 3" in your previous posts (which would be viewed as a very serious error by a mathematician), and your latest statement. Just say "m cannot be a multiple of 3 for all values that I have tried" or more directly "I have a conjecture that m cannot be a multiple of 3". There are some conjectures in mathematics that could be made and found true thousands of times over before being found to be untrue after the millionth try.
