How Does the Selection Sort Algorithm Work?
In summary, Selection Sort involves repeatedly finding the largest element in an array and moving it to its final position. This is done by swapping the element at the highest index and the largest element. The effective size of the array is then reduced and the process is repeated until the array is sorted. The intermediate lists at each step show the elements that have been sorted and the remaining elements to be sorted.
Joystar77
125
Sort with Selection Sort algorithms the following list:
329, 363, 373, 334, 320
Give the intermediate lists at each step.
I found the following information about Selection Sort. It states as follows: "The idea of selection sort is rather simple: the next largest (or smallest) element in the array is repeatedly found and moved to its final position in the sorted array. In order to sort the array in increasing order, the smallest element at the beginning of the array and the largest element at the end, the largest element is selected and moved to the highest index position. This is done by swapping the element at the highest index and the largest element. The effective size of the array is then reduced by one element and the process is repeated on the smaller (sub array). The process ends when the effective size of the array becomes 1 (an array of 1 element is already sorted)."
Can someone please explain this in simpler terms? What does it mean when it says to give the intermediate lists at each step?
Technology news on Phys.org
I will explain this with an example array:
[2, 4, 1, 5, 3]
1.) We find that 5 is the greatest element, so we swap 5 and the element at the last position, and take this out of the array:
[2, 4, 1, 3], 5
2.) Now, for the remaining four elements in the array, we find 4 is the greatest element, so we swap 4 with the element in the last position and take it out of the array:
[2, 3, 1], 4, 5
3.) For the remaining three elements, we find that 3 is the greatest element, so we swap it with the element in the last position and take it out of the array:
[2, 1], 3, 4, 5
4.) For the remaining two elements, we find 2 is the greatest element, so we swap it with the element in the last position and take it out of the array:
[1], 2, 3, 4, 5
Now we are down to an array of one element, and the original array is sorted:
1, 2, 3, 4, 5
Is this correct with Selection Sort?
329, 364, 373, 334, 320
[329, 364, 334, 320], 373
[329, 334, 320], 364, 373
[329, 320], 334, 364, 373
[320], 329, 334, 364, 373
320, 329, 334, 364, 373
Are the intermediate lists at each step around the parentheses or brackets?
The brackets denote those elements still in the array. It looks like you are removing the greatest element without making the required swap.
MarkFL, can you please then correct what I did because I was trying to follow the example you gave about how to do Selection Sort Algorithms. Does it matter whether or not I use parentheses or brackets?
The algorpthm description says,
What is the element at the highest index in the initial array? It's the element at the end of the array, i.e., 320. What is the largest element? It's 373. Now the description says that you have to swap 320 and 373 in [329, 364, 373, 334, 320]. You get
329, 364, 320, 334, 373,
and not
329, 364, 334, 320, 373,
as your second line says.
Now you exclude the last element (373), restrict you array to the first four elements and do the same.
Evgeny.Makarov! I don't quite understand what your doing in this process of Selection Sort. Is this correct then as follows:
[329, 364, 320, 334], 373
Yes, this is correct.
What is a selection sort algorithm?
A selection sort algorithm is a sorting method where the list of elements is divided into two parts: the sorted part and the unsorted part. The sorted part is initially empty, and the unsorted part contains the entire list. The algorithm then finds the smallest (or largest) element in the unsorted part and swaps it with the first element in the unsorted part. This process is repeated until all elements are in the sorted part.
How does a selection sort algorithm work?
A selection sort algorithm works by finding the smallest (or largest) element in the unsorted part of the list and swapping it with the first element in the unsorted part. This process is repeated until all elements are in the sorted part, and the list is fully sorted.
What is the time complexity of a selection sort algorithm?
The time complexity of a selection sort algorithm is O(n^2) in the worst case, where n is the number of elements in the list. This means that the time taken to sort a list using a selection sort algorithm increases quadratically as the number of elements in the list increases.
What is the space complexity of a selection sort algorithm?
The space complexity of a selection sort algorithm is O(1), which means that the algorithm requires a constant amount of extra space to sort the list, regardless of the number of elements in the list.
What are the advantages and disadvantages of using a selection sort algorithm?
The main advantage of using a selection sort algorithm is that it is simple to implement and requires a small amount of extra space. However, it has a relatively slow time complexity compared to other sorting algorithms and is not a suitable choice for sorting large lists.
