Solving Math Problems: Selecting 7 Out of 16 Seated Men on a Round Table
  • Thread starter Wiz
In summary: I'm not challenging the question but trying to guide you in the right direction by asking questions. In summary, the conversation was about finding the number of ways to select a certain number of people from a group of people sitting at a round table, without selecting anyone who is sitting next to each other. The final answer was determined using a matrix and the formula C = a_{\delta p} + \sum_{x = 1}^{\delta} a_{xp}.
Wiz
I am stuck on this prob...16 men are seated along a round table...in how many ways can i select 7 out of em such tht none of the selected individual were sitting next to each other?...
thanks
Mathematics news on Phys.org
In how many ways could you select 8 men? In how many fundamentally different ways (that is, without being able to rotate/flip one into another)can you select 7 men?
i don't get u...wht are u trying to say??.are u challenging the question or asking me a question which i myself posted on the forum?...what??
Hmmm...I was trying to be pedagogical. See if I could point you in the right direction by asking some slightly different questions, rather than just stating the solution.
Another try: We have to select 7 persons with gaps (of at least one person) between them. This is equivalent to selecting 7 gaps (of at least one person) with exactly one person in between. Now, in how many ways can you distribute the remaining 9 persons over the 7 gaps? We've got two different cases:
(1) We've got a gap of three persons, like: #000#0#0#0#0#0#0 (where # denotes selected). In how many ways can you do this?
(2) We've got two gaps of two persons, like: #00#00#0#0#0#0#0. In how many ways can you do this?
By the way: I get 14 + 42 = 56 possible ways.
hmm...i get ur method..but ur ans is wrong..check it again..in the meanwhile i'll give it another shot..do post ur corrected ans...thanks.
Oh yes, I see, I made a mistake.
(1) In this case the selection is characterized by the position (of the middle person) of the gap of three. So there are 16 different possible selections.
(2) Now the selection is characterized by the position of the two gaps of two persons. The 'first' gap (of two) can be chosen arbitrary, so 16 possibilities. The second gap (of two) can be chosen from the 7-1=6 remaining gaps between selected persons. Now we have to divide by two because the gaps (of two) could interchanged to yield the same selection. So we get 16 x 6 / 2 = 48 possible selections.
Conclusion there are 64 possible selections.
ok thtz correct...but is there a way to generalise it??...say selection of r persons out of n ppl??.(in the same prob)
First, build a matrix like
[tex]A = \left[ \begin{array}{ccccc} a_{11} & a_{12} & a_{13} & a_{14} & . . . \\ a_{21} & a_{22} & a_{23} & a_{24} & . . . \\ a_{31} & a_{32} & a_{33} & a_{34} & . . . \\ \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
Where [tex]a_{1j} = 1 [/tex] and [tex]a_{n1} = 1 [/tex], and define : [tex]a_{ij} = a_{(i - 1)j} + a_{i(j - 1)}[/tex]
Your matrix will look like:
[tex]A = \left[ \begin{array}{ccccc} 1 & 1 & 1 & 1 & . . . \\ 1 & 2 & 3 & 4 & . . . \\ 1 & 3 & 6 & 10 & . . . \\ \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
Problem: n people in a round table. No 2 selected people sits next to each other. Select p people.
Calculate: [tex]\delta = n - (2(p - 1) + 1)[/tex]. Then the total number of ways is :
[tex]C = a_{\delta p} + \sum_{x = 1}^{\delta} a_{xp}[/tex]
I wonder if anyone has discovered this. Anyway, if no one else has. Let’s call it ‘The little theorem of Viet Dao’. :wink:
EDIT : This formula can be horribly wrong if there is no way to select.
Viet Dao,
i understood absolutely nothing in ur previous post...could u please explain??...
Okay, a matrix m x n is defined as:
[tex]A_{m x n} = \left[ \begin{array}{ccccc} a_{11} & a_{12} & a_{13} & . . . & a_{1n} \\ a_{21} & a_{22} & a_{23} & . . . & a_{2n} \\ \vdots & \vdots & \vdots & \vdots & . . . \\ a_{m1} & a_{m2} & a_{m3} & . . . & a_{mn} \end{array} \right][/tex]
[tex]a_{ij}[/tex] 0 < i < m, 0 < j < n is one item in the matrix. For example, i = 1, j = 1, then you will have [tex]a_{ij} = a_{11}[/tex]
And my matrix will have [tex]a_{1j} = 1 \mbox{ and } a_{i1} = 1[/tex]
So it will look like:
An item [tex]a_{ij}[/tex] is the one that lies on the i row, and the j column of the matrix.
[tex]A = \left[ \begin{array}{ccccc} 1 & 1 & 1 & 1 & . . . \\ 1 & a_{22} & a_{23} & a_{24} & . . . \\ 1 & a_{32} & a_{33} & a_{34} & . . . \\ \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
Then I say : [tex]a_{ij} = a_{(i - 1)j} + a_{i(j - 1)}[/tex]
Example : [tex]a_{22} = a_{12} + a_{21} = 1 + 1 = 2[/tex]
[tex]a_{23} = a_{13} + a_{22} = 1 + 2 = 3[/tex]
The item [tex]a_{ij}[/tex] is the sum of the item above it and the item to the left of it.
And so on, so my matrix will look like:
Then I calculate : [tex]\delta = n - (2(p - 1) + 1)[/tex]. There are 2 cases:
1. [tex]\delta \leq 0[/tex] : No selection.
2. [tex]\delta > 0[/tex]:
Then the number of selection will be:
It means:
[tex]C = a_{\delta p} + a_{1p} + a_{2p} + a_{3p} + ... + a_{\delta p}[/tex]
Where p is the number of people you want to select, n is the total number of people sitting on the round table.
* Solving your problem using my method:
[tex]\delta = n - (2(p - 1) + 1) = 3[/tex]
p = 7, n = 16 (This is what you have total people = 16, number of selected people = 7).
[tex]A = \left[ \begin{array}{ccccccc} 1 & 1 & 1 & 1 & 1 & 1 & 1. . . \\ 1 & 2 & 3 & 4 & 5 & 6 & 7. . . \\ 1 & 3 & 6 & 10 & 15 & 21 & 28. . . \\ \vdots & \vdots & \vdots & \vdots & \vdots & \vdots & . . . \end{array} \right][/tex]
So you will have:
[tex]= a_{37} + a_{17} + a_{27} + a_{37} = 28 + 28 + 7 + 1 = 64.[/tex]
So there are 64 different ways to randomly choose 7 people, in which in every 2 selected people, they don't sit next to each other.
You can try another number of people sitting on the table (n), and the number of selected people (p).
You can use this as a method to check your answer.
Viet Dao,
What are "Selections math problems"?
"Selections math problems" are mathematical problems that involve choosing or selecting certain elements or combinations from a given set of options. These types of problems often require critical thinking and logical reasoning to arrive at the correct solution.
What strategies can I use to solve "Selections math problems"?
Some strategies that can be helpful in solving "Selections math problems" include creating a diagram or chart to visualize the options, using the process of elimination, and breaking the problem down into smaller steps.
How do I know which selection to choose in a "Selections math problem"?
The key to solving "Selections math problems" is carefully reading and understanding the problem to determine the criteria for the selection. It is also important to consider any given constraints or limitations and use logical reasoning to eliminate incorrect options.
Can "Selections math problems" be solved using multiple methods?
Yes, there may be multiple ways to approach and solve a "Selections math problem". It is important to find a method that works best for you and that you are comfortable with. It is also helpful to check your work using a different method to ensure accuracy.
What are some real-life applications of "Selections math problems"?
"Selections math problems" can be used to solve various real-life problems, such as making choices in decision-making, optimizing resources and time management, and solving puzzles and riddles. These types of problems are also commonly used in fields such as computer science, engineering, and economics.
  • Precalculus Mathematics Homework Help
