Sensation of weightlessness homework
In summary: Therefore, the sensation of weightlessness is due to the absence of contact forces and the presence of only one non-contact force, gravity.In summary, the sensation of weightlessness in a spacecraft in orbit is due to the absence of contact forces, as all contact forces are removed, and the presence of only one non-contact force, gravity. This is because the spacecraft is in free fall, where the only force acting on it is gravity, causing its acceleration to match the acceleration due to gravity. The spacecraft is also shielded from other gravitational forces by its own structure. Therefore, the sensation of weightlessness is not due to the spacecraft having no energy, as it is constantly in motion due to its orbit.
ritwik06
580
The sensation of weightlessness in a spacecraft in orbit is due to:
a) abscense of gravity
b)acceleration in orbit equal to acceleration due to gravity.
c)Shielding from gravity provided by spacecraft
d) spacecraft in orbit has no energy
I would mark a) right. do you agree?
What do you think is keeping the spacecraft in orbit?
Weightless sensations exist when all contact forces are removed. Gravity is a non-contact force!
This would certainly appear to be a question from a school test, in which case it should be in the homework section. That having been said, your answer is wrong. The correct answer is very easy to establish if you pay attention to the circumstances outlined in the question. To start with, what is an 'orbit'?
The centripetal and centrifugal force, isn't it?
An orbit is the path traced by a heavenly body while going around another massive heavenly body
And how do we get centripetal force?
Okay, from that definition, is it possible for you to see why the answer you chose is wrong?
There are two distinct things called "weight", both having units of force. One is the force on an object due to gravity, which is called the object's "actual weight". The other weight, "apparent weight", is what scales, accelerometers, and the otoliths in your inner ear measure. Weightlessness occurs when an object has negligble apparent weight.
I don't want to say much more until the original poster gets the right answer on his/her homework.
This is not quite correct. Suppose I solidly embed an accelerometer in a metal sphere. Now suppose I charge the sphere and release it in a vacuum in which a strong static electrical field is present. The accelerometer will not sense the acceleration due to gravity but it will sense the acceleration due to the electrical field. No device can be constructed that directly senses gravitational acceleration. This is a consequence of the equivalence principle.
Weightless sensation exists when the acceleration of a body is equal to the acceleration due to the gravitation force on the body.
What I was simply implying is that an object in free fall will have no apparent weight, since there is no contact with the surface and no normal or reaction force. The object does have actual weight which is the downward force upon the object by gravity. Hence an object in free fall has all contact forces removed where the only force gravity (non-contact) is acting on the object.
What causes the sensation of weightlessness in space?
The sensation of weightlessness in space is caused by the lack of gravity. In space, objects are in a constant state of freefall, which creates the feeling of weightlessness.
Can the sensation of weightlessness be experienced on Earth?
Yes, the sensation of weightlessness can be experienced on Earth through methods such as parabolic flight, where an aircraft follows a specific trajectory to simulate the effects of microgravity.
What are some of the physiological effects of prolonged weightlessness?
Prolonged weightlessness can cause a variety of physiological effects such as loss of muscle and bone mass, changes in the cardiovascular system, and a weakened immune system. These effects can be mitigated through exercise and other countermeasures.
How do astronauts prepare for the sensation of weightlessness in space?
Astronauts undergo extensive training to prepare for the sensation of weightlessness in space. This includes simulations, parabolic flights, and exercises to help them adapt to the effects of microgravity on the body.
What are some potential challenges with the sensation of weightlessness in space?
The sensation of weightlessness in space can pose challenges for tasks such as eating, sleeping, and performing daily activities. It can also affect the functionality of equipment and require adjustments to standard procedures.
