1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Separable Partial ODE
  1. Nov 4, 2008 #1
    Find the general solution of:
    x.du/dx - (1/2).y.du/dy=0
    I know that for it to be separable u(x,y)=X(x)Y(y)
    x.Y(y)dX/dx + (1/2).X(x)dY/dy = 0
    which cancels to:
    x/X(x).(dX/dx) = - y/2Y(y).dY/dy
    X(x) = -c. Y(y) c is some constant
    x/X(x).dX/dx = c
    from here i am stuck. Any help appreciated
  3. Nov 4, 2008 #2
    Staff Emeritus
    You lost a minus sign in your second equation.
    Also, separation of variables is your friend. Just because you learned a method of solving differential equations a while ago doesn't mean you should abandon it
    [tex]\frac{x}{X(x)}\frac{dX}{dx} = c[/tex]
    [tex]\frac{dX}{X} = c \frac{dx}{x}[/tex]
  4. Nov 4, 2008 #3
    Thanks I get
    c.ln(x) + C=ln(X) => X=Ax^C
    c.ln(y) +C= 1/2 ln(Y) => Ay^2C
    so u(x,y)=X.Y=A^2(y^2C)(x^C)
    ...the contants for integration are required right? Just wondering because the second part of the question would be easier if they weren't there:
    determine u(x,y) which satisfies the boundary conditon u(1,y)= 1 +sin y
    I would go about this by making 1+siny = A^2((1)^C(Y^2C))
    => A^2=[1 - Sin(y)]/[y^2C]
    so u(x,y) satisfied by the boundary condtion is:
    u(x,y)=[1 - Sin(y)]/[y^2C].x^C.y^2C
    y^2C cancel so:
    u(x,y)=[1 - Sin(y)].x^C
    BUT how do you get rid of that C or am i being stupid and iv made a previous mistake/mistakes
    EDIT :OK Long winded but from finding out X and Y I can find the original c and hence A by finding the ratio between X an Y which is x/y^2 so A is known. Then the boundary condtion is simply finding the constant of integration c with known A? Il leave the previous mess on the post just to check your opinion.
  5. Nov 4, 2008 #4
    Staff Emeritus
    You have some sloppy coefficient carrying there, but got lucky and ended up with an equivalent formula anyway
    [tex] ln(X) = cln(x) + C_x[/tex]
    which gives us
    [tex]X = x^c*A_x[/tex] where [tex] A_x = e^{C_x}[/tex]. This is important because the constant of integration obtained in the formula for Y need not be the same (it happens not to matter in this case, but you could shoot yourself in the foot). Similarly
    [tex]\frac{dY}{Y} = 2c\frac{dy}{y}[/tex] which gives us
    [tex]ln(Y) = 2cln(y) + C_y[/tex]
    and hence
    [tex]Y = A_yy^{2c}[/tex] where [tex]A_y = e^{C_y}[/tex].
    [tex]u(x,y) = A_xA_yx^cy^{2c}[/tex] we combine the multiplicative constants to get
    [tex]u(x,y) = Ax^cy^{2c}[/tex]
    But hark! This gives not the final solution. Because any linear combination of these is also a solution. In particular any infinite summation that happens to uniformly converge is also a solution. You know an infinite summation of 1+siny in terms of y, so try finding A's and c's such that when you sum up all the terms and set x=1 you get the power series of 1+siny
