Sequence Converging Proof
  • Thread starter Mush89
Prove that if the sequence {An} converges to A, then the sequence {|An|} converges to |A|. And is the converse true?
This is for my calculus class and it needs to be in proof format. Thank you!
I'm totally lost, I was going to use ||x| - |y|| less than/or equal to |x-Y| but I'm not really sure where to go from there and if that's even right.
Answers and Replies
Just insert this inequality into the formal epsilon definition of the limit and you're done.
For the converse, consider the sequence 1,-1,1,-1,...
So, find the limit of that inequality?
What is the epsilon definition of the limit of a sequence?
Reversed Triangle Inequality will work:
l l An l - l A l l ≤ l An -A l
*Use formal espilon definition
l An - A l ≤ l An l - l A l
Above used for proving the Forward Direction
I don't think that works, because epsilon is on the right hand side ... you really need the other inequality already given by Mush89.
Opps! My bad! I guess the second inequality i've mentioned will be enough ..
Related Threads on Sequence Converging Proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
