Sequence of ratios of primes and integers
In summary, the sequence a_n is monotone decreasing for all natural numbers N, but the tail of the sequence a_n is not monotone. The alternating series test shows that \sum_n(-1)^n\frac{n}{p_n} converges.
Dragonfall
1,030
I am fairly certain that [tex]\frac{n}{p_n}[/tex] is not monotone for any n, but I can't give a proof of it without assuming something at least as strong as the twin prime conjecture. I was wondering if anyone has some advice to prove this using known methods?
Statement is confusing - what is variable (not n from what you said)?
The variable is n. I mean no tail of the sequence is monotone.
Any ideas at all? I'm drawing dead here.
I'm still not sure what you mean, exactly.
The tail of a sequence [tex]a_n[/tex] is the subsequence [tex](a_n)_{n>N}[/tex] for some N. A sequence may not be monotone for the first N numbers, but the tail of the sequence might be monotone. If [tex]\frac{n}{p_n}[/tex] is eventually monotone, then the alternating series test shows that [tex]\sum_n(-1)^n\frac{n}{p_n}[/tex] converges. I believe that the series converges, but I don't think the sequence is eventually monotone, mainly because I think the twin prime conjecture is true.
I still have no idea what you mean, but [tex]\sum_{n=1}^{\infty} \frac{n}{p_n}[/tex] diverges if that helps.
Ok I don't know how I can possibly make it clearer. Look at this sequence:
2, 3, 5, 3, 5, 6, 7, 6, 4, 2, 1/11, 1/12, 1/13, 1/14, 1/15, 1/16, 1/17, 1/18, ...
This sequence is monotone decreasing from the 11th entry onwards. IS THE SAME TRUE FOR [tex]\frac{n}{p_n}[/tex]? I don't think so, but it is not obvious either way.
Just a quick suggestion
Have you tryed to link it with http://mathworld.wolfram.com/PrimeNumberTheorem.html" ?
All I can conclude from PNT is that [tex]\lim\frac{n}{p_n}=0[/tex].
Dragonfall,I just realized what was your question in a first place...
I think it's darn difficult to prove that!
Need to know of distribution of primes for every finite segment [n,n+k] of natural numbers.Looks intractible at first glance.Sorry.
No, it doesn't.
DeadWolfe said:
No, it doesn't.
Why not? [itex]\lim_{n\to \infty}\frac{n}{p_n}=0[/itex] by the PNT, so wouldn't eventual monotonicity be sufficient for convergence?
Anyway, let's just see what we have.
No tail is monotone if for all natural numbers N, there is an n>N such that
[tex]\frac{n}{p_n} < \frac{n+1}{p_{n+1}}[/tex].
This is equivalent to
[tex]np_{n+1}<np_n+p_n[/tex]
[tex]p_{n+1}-p_n<\frac{p_n}{n}[/tex]
You don't need the twin primes conjecture here. It suffices to have this lemma:
There exists a natural number k such that there are infinitely many consecutive primes whose difference is less than k.
Even this is stronger than you need, but much, much weaker than the twin primes conjecture.
My deepest apologies, I somehow had forgotten the correct statement of the alternating series test.
Man do I feel stupid.
Thanks, and you're right, something like "there exists infinitely many n such that [tex]p_{n+1}-p_n<\log n[/tex]" is approximately what I need.
Don't feel stupid. Stuff like that happens to me all the time.
Anyway, I did some looking, and I found this paper, which states that if the Elliot-Halberstam Conjecture is true, then there are infinitely many consecutive primes differing by less than 16.
I can't seem to find any similar results that don't depend on unproven conjectures, so proof might not be easy.
A proven result that might be useful is that [itex]{\lim \inf}_{n \to \infty} \frac{p_{n+1}-p_n}{\log{p_n}}=0[/itex] (found in the same paper).
I'm reading through it now, thanks. An immediate corollary is that [tex]\lim\inf\sqrt{p_{n+1}}-\sqrt{p_n}=0[/tex], which brings us infinitesimally closer to Andrica's conjecture (I haven't had time to think it through, it's just the first thing that popped into my head).
After a bit of tinkering and smoothing out some holes in the logic, I've come up with a proof of your conjecture using [itex]{\lim \inf}_{n \to \infty} \frac{p_{n+1}-p_n}{\log{p_n}}=0[/itex] as a lemma. I'll post it if you want to see.
I'll try and figure it out myself. If I get stuck maybe I'll crack and ask for your proof.
Fair enough. That's why I asked.
If you do manage to prove it, I'd love to see your proof. Please do post it.
Ok I cracked. I haven't gotten much time to think about it, and I'm really just curious now. Can you show your proof?
From Wikipedia:
In 1940, Paul Erdős showed that there is a constant c < 1 and infinitely many primes p such that (p′ - p) < (c ln p) where p′ denotes the next prime after p. This result was successively improved; in 1986 Helmut Maier showed that a constant c < 0.25 can be used. In 2004 Daniel Goldston and Cem Yıldırım showed that the constant could be improved further to c = 0.085786… In 2005, Goldston, János Pintz and Yıldırım established that c can be chosen arbitrarily small [1], [2]:
From Mathworld you'll also find a reference showing that
[tex] 0.922 \frac{n}{\ln n} < \pi(n) < 1.105 \frac{n}{\ln n}.[/tex]
That looks like enough to me. :smile:Edit: Woops! Looks like I'm a little late. I hate posting in older threads by accident!
My proof is as follows:
We want to show, that for any [itex]m[/itex] no matter how large, there is an [itex]n>m[/itex] such that
[tex]\frac{n}{p_n}<\frac{n+1}{p_{n+1}}[/tex]
We can rearrange this:
[tex]np_{n+1}<p_n(n+1)[/tex]
[tex]np_{n+1}-np_n<p_n[/tex]
[tex]\frac{p_{n+1}-p_n}{\log{p_n}}<\frac{p_n}{n\log{p_n}}[/tex]
Thus our theorem is established if we can show that [itex]\frac{p_{n+1}-p_n}{\log{p_n}}[/itex] can be made smaller than [itex]\frac{p_n}{n\log{p_n}}[/itex] for [itex]n[/itex] arbitrarily large.
It is an established result by Daniel Goldston and Cem Yıldırım that
[tex]{\lim \inf}_{n \to \infty} \frac{p_{n+1}-p_n}{\log{p_n}}=0[/tex]
Therefore, for any [itex]\epsilon>0[/itex], we can find an arbitrarily large [itex]n[/itex] such that
[tex]\frac{p_{n+1}-p_n}{\log{p_n}}<\epsilon[/tex]
The prime number theorem states that
[tex]\pi(n) \sim \frac{n}{\log{n}}[/tex]
which is useful here:
[tex]n = \pi(p_n) \sim \frac{p_n}{\log{p_n}}[/tex]
This means concretely that
[tex]\lim_{n \to \infty} \frac{p_n}{n\log{p_n}} = 1[/tex]
Therefore we can find an [itex]N[/itex] such that for all [itex]n \geq N[/itex],
[tex]\frac{p_n}{n\log{p_n}} > \frac{1}{2}[/tex]
But by Goldston and Yıldırım, we can find an [itex]n[/itex] as large as we like such that
[tex]\frac{p_{n+1}-p_n}{\log{p_n}}<\frac{1}{2}[/tex]
and thus we have established our theorem!
---Q-E-D---
If you have any questions about it, please post them. :)
An alternate argument using what I posted (when you add the mathworld result, I'm using on the one hand stronger and on the other hand weaker results than Moo did in his proof. They're almost identical. I'd say his is cleaner, though):
We have (from the mathworld ref.), for all natural n,
[tex]0.5 \frac{p_n}{\ln p_n} < \pi(p_n) = n < 2\frac{p_n}{\ln p_n},[/tex]
so in particular
[tex]\frac{p_n}{n} > \frac{\ln p_n}{2}[/tex].
Let N be some natural. By my Wikipedia ref., there is [itex]c<1/2[/itex] and [itex]n>N[/itex] s.t.
[tex]p_{n+1} - p_n < c\ln p_n < \frac{\ln p_n}{2} < \frac{p_n}{n},[/tex]
as required.
Fascinating. Thanks to you both!
1. What is the sequence of ratios of primes and integers?
The sequence of ratios of primes and integers is a mathematical sequence that represents the division of prime numbers by integers. It can be written as P(n)/n, where P(n) is the nth prime number and n is any integer.
2. What is the significance of this sequence?
This sequence is significant because it reveals patterns and relationships between prime numbers and integers. It can also be used to study the distribution of prime numbers and their properties.
3. How is this sequence related to other mathematical concepts?
This sequence is related to various mathematical concepts such as number theory, prime factorization, and the Riemann zeta function. It also has applications in cryptography and coding theory.
4. Can the sequence of ratios of primes and integers be predicted?
While there is no definitive way to predict this sequence, there have been various conjectures and theories proposed by mathematicians. However, the distribution of prime numbers is still a topic of ongoing research in mathematics.
5. Are there any real-world applications of this sequence?
Yes, the sequence of ratios of primes and integers has applications in various fields such as cryptography, coding theory, and data compression. It also has implications in the study of prime numbers and their properties, which have practical applications in fields such as cybersecurity and data encryption.
  • Math Proof Training and Practice
  • Linear and Abstract Algebra
  • General Math
