Homework Help: Series and convergence
  1. Sep 4, 2016 #1
    The problem states: In the harmonic series ##\sum_{1}^{\infty} \frac{1}{k}##, all terms for which the integer ##k## contains the digit 9 are deleted. Show that the resulting series is convergent.
    Hint: Show that the number of terms ##\frac{1}{k}## for which ##k## contains no nines and ##10^{p-1} \leq k < 10^p## is less than ##9^p##.
    2. Relevant equations
    3. The attempt at a solution
    Well, it is not hard to show and see the required in the hint, but other than that the sum of less terms will be smaller than the original number of terms in the harmonic series, I am not sure how I can deduce the convergence. Can't see any link to convergence.
    I would be happy to get help in this exercise.
    Thank you.
  3. Sep 4, 2016 #2
    PeroK
    What are the simplest series you can think of?
  4. Sep 4, 2016 #3
    Mark44
    Staff: Mentor
    I'm having a hard time understanding what this means. Is this the exact wording of the hint?
  5. Sep 4, 2016 #4
    well, I can think of ##\sum \frac{1}{k^2}##. Still can't see how to use it...
    Yes, those are the exact words. It means how many numbers there are between, for example 10 to 99(included), which do not have the digit 9. Example 19 is not counted, and also 95. So the hint says to show that there are, for example, between 10 to 99, less numbers without the digit 9 than 9^p, and not just between 10 to 99, but also between 100 to 999 and so on.
  6. Sep 4, 2016 #5
    Mark44
    Staff: Mentor
    It was this part:
    I think what this is saying is that k < 9p, where ##10^{p-1} \leq k < 10^p##. As written, it suggests that ##10^p < 9^p##.
  7. Sep 4, 2016 #6
    PeroK
    I assumed they were aiming for a geometric series.
  8. Sep 4, 2016 #7
    Thanks for the answers.
    I understood that the number of terms is less than 9^p, which is, well, true.
    Then I need a bit more help here.
  9. Sep 4, 2016 #8
    PeroK
  10. Sep 4, 2016 #9
    Ray Vickson
    For ##10^{p-1} \leq k < 10^p## you have no more than ##9^p## relevant terms, and each relevant term ##1/k## is ##\leq 10^{1-p}##, so what could you say about the sum of such ##1/k##?
Have something to add?
Draft saved Draft deleted
