Homework Help: Series circuit problem
  1. Sep 12, 2014 #1
    1.A circuit consists of 3 resistors connected in series to a 24.0 V battery. The current in the circuit is 32.0 mA. If 2 of the resistors are 250.0  and 150.0 ,
    find the value of the third resistor.
    find the potential difference across each resistor.
    2. R=V/I
    3. I calculated the third resistor to be 350 ohms
    I am confused on what this means "find the potential difference across each resistor."
    What equation do I use for this?
  3. Sep 12, 2014 #2
    You know the current through each resistor and you know the resistance for each.
    You need the voltage. What equation would you use?
  4. Sep 12, 2014 #3
    Use the term "voltage drop" instead of potential difference, and you'll have the answer. :)
  5. Sep 12, 2014 #4
    Isn't the voltage given though at 24 v?
  6. Sep 12, 2014 #5
    NascentOxygen
    Staff: Mentor
    Yes, so when you sum the three resistor voltages the result must equal 24V. Determine the separate resistor voltages. Apply Ohm's Law.
Have something to add?
Draft saved Draft deleted
Loading...
