Series Convergence: Integral Test and Homework Equations
In summary: First of all, you need to take into account that the sum will get an extra n (for example, if you can bound all terms in the sum from above by M, your sum will be like M n). For example: even though 1/n converges to zero, the sum over n = 1 to infinity of 1/n will go like n / n = 1 and will diverge.Even then it is not guaranteed, for example, it is not clear if the sum over 1/(n log n) converges (for n > 1 for example; even if it does, it does so very slowly) although n/(n log n) goes to zero.So you shouldn't use my general rules as
razored
173
Determine whether this series converges or diverges :
http://mathbin.net/equations/7548_0.png
Integral Test
http://mathbin.net/equations/7548_1.png from that it shows to diverge but book says it converges. What did I do wrong?
Where did you get the ln| ... | from?
Try [itex]1/e^{n^2}[/itex] as a primitive.
I don't understand what you mean.
Just use a substitution for n2:
Let u = n2 and du/2n = dn. The n's will cancel leaving you with an easy integral to evaluate. Then use the fundamental theorem to get a (convergent) answer. There shouldn't be any Ln's in your answer!
Oh, so the integral is [tex]\frac{-1e^{-n^2}}{2}[/tex]. Okay, now it converges. Thanks!
In general there are some rules which can help you determine whether your answer is correct. For example:
  • in polynomials, the highest power wins. For example, x/x^2 converges, [itex]6 x^3 \sqrt{x} / (12 x^4)^{5/6}[/itex] diverges because it goes like [itex]x^{7/2}/x^{10/3} = x^{1/6}[/itex] which has positive power.
  • logarithms converge slower than polynomials, e.g. x/log(x) will diverge.
  • exponentials go faster than any polynomial, for example [itex]x^{999999}/e^x[/itex] converges while [itex]x^{-9999999} e^x [/itex] diverges.
You will find more of these as you go, they can often help you make an estimate.
In this case, the terms in the sum converge to 0 much faster than 1/n, so in general you expect a convergent sum.
My textbook left those out. They probably assumed the student would figure them out themselves. Thank you for pointing them out!
Just to stress my point, they will not always help you.
So you shouldn't use my general rules as more than rules of thumb, and always use a rigorous method to prove convergence.
1. What is the Integral Test for series convergence?
The Integral Test is a method used to determine if an infinite series converges or diverges. It involves comparing the series to an improper integral, and if the integral converges, then the series also converges.
2. How do you apply the Integral Test to a series?
To apply the Integral Test, you first need to check if the series is positive and decreasing. Then, find the corresponding improper integral and evaluate it. If the integral converges, then the series also converges. If the integral diverges, then the series also diverges.
3. Can the Integral Test be used for all series?
No, the Integral Test can only be used for series with positive and decreasing terms. If the terms are not positive and decreasing, then the test cannot be applied.
4. What is the advantage of using the Integral Test over other tests for series convergence?
The advantage of using the Integral Test is that it is often easier to evaluate an improper integral than to determine the limit of a series. It can also be used for series with terms that are difficult to manipulate algebraically.
5. Are there any limitations to the Integral Test?
Yes, the Integral Test cannot determine the convergence or divergence of alternating series. It also cannot be used for series with non-decreasing terms or terms that do not approach zero. In these cases, other tests such as the Alternating Series Test or the Comparison Test should be used.
