TTob
- 21
Check if the following series is convergent.
[tex]
\sum^{\infty}_{i=1}l n(cos(\frac{1}{n}))
[/tex]I have tried a lot of different tests without success.
I need some hint.
Thanks
A series convergence is a mathematical concept that refers to the behavior of an infinite sequence of numbers. It describes whether the sum of the terms in the sequence approaches a finite number or if it diverges to infinity.
There are multiple methods for determining the convergence of a series. These include the ratio test, comparison test, integral test, and alternating series test. Each of these methods has its own set of conditions and criteria for determining convergence.
Absolute convergence refers to a series that converges regardless of the order in which the terms are added, whereas conditional convergence refers to a series that only converges when the terms are added in a specific order. In other words, absolute convergence guarantees convergence, while conditional convergence does not.
While there are no shortcuts or tricks that apply to all series, there are some general rules that can help determine convergence. For example, if a series has terms that approach zero as n approaches infinity, it is likely to converge. Additionally, if a series has alternating positive and negative terms, the alternating series test can be used to determine convergence.
If you are having trouble determining the convergence of a series, it can be helpful to try different methods and compare their results. Additionally, seeking help from a teacher, tutor, or online resources can provide valuable insights and tips on solving difficult series convergence problems.
