Homework Help: Series Solution Near an Ordinary Point
  1. Apr 12, 2012 #1
    Determine φ''(x0), φ'''(x0), and φ(4)(x0) for the given point x0 if y=φ(x) is a solution of the given initial value problem.
    y'' + (sinx)y' + (cosx)y = 0 y(0) = 0; y'(0) = 1
    2. Relevant equations
    y = φ(x) = Ʃan(x-x0)n
    3. The attempt at a solution
    I started off by differentiating y to get y' and y''. I then plugged those into the original equation, adjusted the numbers a bit to get the entire equation to fit into one summation. From there, I factored out xn, then set the bulk of the equation equal to 0. From there, I solved for an+2, plugged in n=0 to get:
    a2 = (-(sinx)a1 - (cosx)a0))/2
    This is where I get stuck. I am unsure as to what I'm supposed to do from here, although I have ideas. Am I just supposed to somehow solve for a2 and plug it into the φ''(x) equation? If so, where do I get a1 and a0 from?
    Also, I apologize for not knowing how to do the graphic code to make it look as it looks on paper. Thank you!
    UPDATE: Assuming I am correct, I have solved for a2, a3, and a4 when setting a0 = y(0) and a1 = y'(0).
    How do I use these newfound numbers to solve for the solutions?
    a2 = 0
    a3 = -1/6
    a4 = 0
Draft saved Draft deleted
