Set Theory (Countable Proof)
  • Thread starter gutnedawg
gutnedawg
35
Prove that the fraction m/n occurs in position
[tex] \frac{m^2 +2mn + n^2 - m -3n}{2} [/tex]
of the enumeration {1/1, 1/2, 2/1, 1/3, 2/2, 3/1,...}
of the set Q+ of positive rational numbers. (Hint: Count how many terms precede m/n in the enumeration.)
I'm not sure how to 'prove' this. But what I know is that Q is countable so I know that if I can count to a position j and plug in the m and n into the above formula I will get j.
Answers and Replies
lanedance
3,304
i would start by seeiong if you can finde a general form for the number of terms for a given m+n eg.
m+n = 2 gives 1/1, so there is 1 term
m+n = 3 gives 1/2, 2/1, 1/3, so there is 3 terms
gutnedawg
35
could I write that:
m+n=a_j and call this a set with a_j elements
then create a position set {{1/1},{1/2,2/1},{1/3,2/2,3/1},...} that is a_0,a_1,a_2 etc...
the position would be the addition of the number of elements in a_0+a_1+a_2...
I don't know where I'm going with this
lanedance
3,304
ok so let p = m+n, and N_p, be the number of terms corresponding to p
for
p = 2, gives 1/1, so N_2 = 1
p = 3, gives 1/2, 2/1, so N_3 = 2
p = 4, gives 1/3, 2/2, 3/1, so N_3 = 3
spotting any pattern, then consider summing over p to account for teh term with p<m+n, whilst you'll need to account for the p=m+n terms before the term separately
note the correction to the original post as well (N_3 case)
gutnedawg
35
for
Yea this was what I was trying to get at however you put it much more elegantly... My question before was how could I 'count' the number that come before m/n in a specific p. IE 3/1 is at position 5 we know p=2 + p=3 =3 but how can I include the fact that 1/3 and 2/2 come before 3/1 within the p=4
lanedance
3,304
I would first start by attempting the part I have given
for this look at the ordering of the terms and compare to m & n and try and spot a pattern
gutnedawg
35
I think it's N_p+m correct?
lanedance
3,304
what is?
gutnedawg
35
what I was thinking is incorrect... I'm just not seeing a pattern that would give me what I need
Loot
the pattern is as follows:
M N
1 1
1 2
2 1
1 3
2 2
3 1
1 4
2 3
3 2
4 1
Use that formula and you'll see that it calculates the 0 based index correctly for the above.
Then with induction:
let P(m,n) be the position
P(m,n) = big equation.
Now, we have to prove that P(m+1,n-1) = P(m,n) + 1
Write it out and you will see that it's provable.
Suggested for: Set Theory (Countable Proof)
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
