What are the best eyepieces for my new Orion XT8 telescope?
  • Thread starter QuantumPion
  • Tags
    orion
In summary, the Orion XT8 telescope comes with one 25 mm eyepiece, so you might want to consider getting a 6-10 mm eyepiece for planetary viewing. A laser collimator is not necessary, but could be helpful for more complex imaging.
QuantumPion
42
I just bought my first telescope, finally settled on the Orion XT8 after originally considering a Celestron 90EQ refractor or 130EQ Newtonian. Figured I might as well get something that will last me a while from the get-go instead of wasting money on lower end scopes.
Anyway, what are some good eyepieces to consider getting? I believe the XT8 only comes with one 25 mm piece, so I think I'd like to get a 6-10mm piece for planetary viewing. Also, should I get one of those laser collimators, or will I be able to get by without one?
Astronomy news on Phys.org
Great scope! Get a good ED shorty barlow if you don't already have a barlow. Your next EP should be in the 10mm range. I would get a good quality LER (long eye relief) eyepiece at the shorter focal lengths or use the plossl with a barlow and a spacer to give a range of magnifications with your 25mm plossl (which should have at least 20mm eye relief). This thread has my recommendations a few pages back.
CONGRATULATIONS on your new telescope.
You can wait on the laser collimator.
I put the scope together last night but by the time I got it ready, it got cloudy out.
Today, it was 100% visibility all day long but as soon as I got home, bam, clouds! Is this a curse or what?
I did manage to get a moon shot though since it was almost full.
Nice job QP!
I took the above by just carefully holding my iphone up to the eyepiece. I have a DSLR, is there a mount I can get which would allow me to mount it directly in front of the eyepiece?
Sweet, on sale too.
I would caution against eyepiece projection photography. It is more difficult than prime focus and generally yields disappointing results. Even planets typically yield better images at prime focus than with eyepiece projection. A good barlow lens is all you probably need.
What would you recommend as the best method for novice astrophotography with my equipment (XT8 scope, Canon EOS 20D camera)?
Without a motorized mount you won't be able to do much astrophotography. You should be able to get images of the planets and moon, but anything more than that is just not going to happen really. If you really want to learn more about it, head over to cloudynights.com and hit up their forum. That site is dedicated to astronomy and there are a lot of resources there.
Prime focus is my suggestion. You will need an adapter to mount the camera to the focuser. I also recommend APT for software. It allows you to preview your shots and is not expensive. You should be able to get decent moon and planet shots even without a clock drive.
Alright I'll look into that. My other question is for eyepieces. I read somewhere that a telescope has the best acuity with an eyepiece focal length equal to about twice the focal ratio. So that would be 12mm for my scope (2*1200mm/203mm). However this would only give me 100x zoom, and I'd like more zoom for planetary viewing. Should I get a 12mm EP and a 2x Barlow? Or a 6mm EP? Or some other combination? Also what is a good recommended eyepiece for < $100 range? I was just going to get the Orion 2x shorty Barlow and the 12mm long eye relief eyepiece from telescope.com, but I was also considering the 12mm ED eyepiece as well, not sure which one would be better or if there is another brand which offers better bang for the buck.
You will discover yourself drawn to widefield eyepieces for general observing. I would suggest something in the 20mm range for this purpose. For planetary viewing, a 9mm ep along with a 2x barlow is a good choice. Unbarlowed it will yield 133x, which will be just about ideal on most nights. With 2x barlow, you can get 266x, which is about as much useful magnification as you can coax out of an 8" primary under very good seeing conditions. In theory, you push it to as much as 400x, but, that assumes near perfect optics and seeing conditions. Not terribly realistic. Owl astronomy has a good selection of good quality eyepieces like these at very reasonable prices.
Just a quick pointer about OWL astronomy; it's a family-run business, and one of their family members is currently recovering from a stroke. I know this after some short email exchanges, where I originally inquired about several of my purchases that had to be refunded due to my purchased items not being in stock, despite seeing the items openly offered on their website, with no warning of them being out of stock.
This isn't to say that they are a bad business; they aren't. I would just expect some unpredictably with certain items.
1. What is the Orion XT8?
The Orion XT8 is a type of telescope known as a Dobsonian reflector, designed for amateur astronomers. It has an 8-inch aperture and is part of the Orion SkyQuest series.
2. How does the Orion XT8 differ from other telescopes?
The Orion XT8 is unique because of its design, which allows for easy set-up and use, as well as its large aperture, which allows for excellent light-gathering capabilities. It also has a relatively affordable price compared to other telescopes of similar quality.
3. What can I see with the Orion XT8?
The Orion XT8 is capable of providing clear views of the moon, planets, and many deep-sky objects such as galaxies, nebulae, and star clusters. With proper filters, it can also be used for solar observations.
4. How difficult is it to set up and use the Orion XT8?
The Orion XT8 is relatively easy to set up and use, even for beginners. It requires minimal tools and can be assembled in less than an hour. The telescope also comes with an instruction manual and online resources for guidance.
5. Can the Orion XT8 be used for astrophotography?
While the Orion XT8 was not specifically designed for astrophotography, it can be used for basic imaging of the moon and bright planets. However, additional equipment and modifications may be necessary for more advanced astrophotography with this telescope.
  • Astronomy and Astrophysics
10K
9K
