Shank with attached spring
  1. Mar 25, 2013 #1
    The shank of a 5-lb vertical plunger is .25 inches above a button when resting in equilibrium against the spring of stiffness k = 10 lb/in. The upper end of the spring is welded to the plunger, and the lower end is welded to the base plate. If the plunger is lifted 1.5 inches above its equilibrium position and released from rest, calculate its velocity as it strikes the button A. Friction is negligible.
    2. Relevant equations
    [itex] E_1=E_2[/itex]
    [itex] PE_{spring} = \frac{1}{2}k(x_1-x_0)^2[/itex]
    [itex] PE_{gravity} = mgh[/itex]
    [itex] KE = \frac{1}{2}mv^2[/itex]
    3. The attempt at a solution
    let y=0 at the equilibrium position .25 inches above the button.
    1.5in = .125 ft
    10 lb/in = 120 lb/ft
    .25 in = .0208 ft
    It is released from rest, so KE1=0.
    My energy balance ends up being:
    [itex] PE_{spring,1} + PE_{gravity,1} = PE_{spring,2} + PE_{gravity,2} + KE_2[/itex]
    Plugging in numbers gives:
    [itex] \frac{1}{2}(1.2)(.125)^2 + (5)(.125) = \frac{1}{2}(1.2)(-.0208)^2 - (5)(.0208) + \frac{1}{2}(\frac{5}{32.2})v^2[/itex]
    I get 4.27 ft/s.
    The correct answer should be 3.43 ft/s. I'm just not sure where I went wrong
  3. Mar 25, 2013 #2
    TSny
    2017 Award
    Did you find the value of ##x_0##?
    Did you mean to let k = 120 lb/ft here?
  4. Mar 25, 2013 #3
    Ah, that's what it was. I forgot that the spring is compressed at the equilibrium point.
    Thank you again!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Shank with attached spring
  1. 2 Springs attached? (Replies: 1)
Loading...
