Shape of an air driven turbine
In summary, the most efficient shape for an air driven turbine depends on the characteristics of the air and the desired flight envelope. For maximum torque, a turbine with a larger diameter and a centrifugal fan design would be most effective. However, for a small shop tool with limited size and weight constraints, it may be more practical to use a compressed air motor with a vane design. The efficiency of the blade design will ultimately determine the torque and power output of the turbine.
zydubion
What is the most efficient shape of an air driven turbine?
I want to achieve the greatest possible torque with the lowest volume of air.
I hope I am posting this in the correct place. If not, any
links would be helpful. Thank you very much.
It depends entirely on the characteristics of the air you are sending through it. Essentially a turbine blade is a wing - and the best shape of a wing depends on the intended flight envelope. So what exactly are you trying to do?
High torque would probably mean getting the most from the air volume you can at low speed. So something the shape of a fan might be best. But that will also mean relativly low power output.
That is a very broad question.
You'll need to list a few more specifics.
Size/weight restrictions?
Cost constraints?
What type of project is it being used for?
etc.
The application is for a small shop tool. The diameter of the turbine would be approximately 1.5 inches, while thickness should be less than 1/4 inch. Compressed air will enter the outer edge of the turbine via a nozzle. The output of the turbine will be interconnected to a substantial gear reduction and finallly to the work.
Look at it logically.
For maximum torque you want the blade to turn as slowly as possible, because of the torque/speed tradeoff, so you want a turbine with the maximum diameter. A propeller type blade is designed to turn fast, so that isn't what you're looking for. You basically need a cenrifugal fan, but operating as a turbine. You can arrange to discharge the air through only part of the perimeter of the turbine to match the load characteristics.
You're right, except that while he THINKS he needs high torque, what he really needs is high rpm and power output. The reduction gear takes care of the torque. But in any case, I'm not sure a pneumatic tool is something that can really be made at home.
from Russ
I agree. I would try to modify an existing device before re-inventing the wheel. There are plenty of pneumatic tools available for consideration. I would bet that one of them already fits the design criteria; ie. pressure, flow, [the total work required], in addition to considerations like the maximum duty cycle; and some other factors like maximum momentary toque and impulse, speed, etc.
From his further description it sounds like he needs a compressed air motor, such as used in a garage, which is a vane type motor, and not a turbine at all.
Perhaps I posted my original question incorectly. Sorry. What I should have said was that I am looking for a blade design that provides the greatest efficiency within the air motor or turbine itself. I want high torque at the air motor output and will of course increase that torque signigicantly via the gear reduction. I am looking for the most efficient use of the input air via a proven blade design. Your reply posts are appreciated.
1. What is the purpose of the shape of an air driven turbine?
The shape of an air driven turbine is designed to efficiently capture and convert the energy of moving air into rotational motion, which can then be used to power other machines or devices.
2. How does the shape of an air driven turbine affect its performance?
The shape of an air driven turbine can greatly impact its performance, as it determines how well the turbine can capture and convert the energy of moving air. A well-designed shape can result in a more efficient and powerful turbine.
3. What factors are considered when designing the shape of an air driven turbine?
When designing the shape of an air driven turbine, factors such as the speed and direction of the air flow, the size and shape of the blades, and the overall aerodynamics of the turbine are all taken into consideration.
4. How does the shape of an air driven turbine differ from a water driven turbine?
The shape of an air driven turbine is typically more streamlined and aerodynamic compared to a water driven turbine, as air is less dense and offers less resistance. Water driven turbines also have to consider the weight and buoyancy of the turbine in addition to the shape.
5. Can the shape of an air driven turbine be modified for different applications?
Yes, the shape of an air driven turbine can be modified for different applications. For example, turbines used for wind energy production may have a different shape than those used in aircraft engines. The specific design will depend on the intended use and desired performance of the turbine.
  • Other Physics Topics
  • Aerospace Engineering
