Determining Shape of Molecules: Water Example
In summary, the shape of molecules is determined by using empirical knowledge and simple models such as VSEPR. These models are not quantitative or based on rigorous theory. To calculate geometries from pure theory, explicit quantum-mechanical calculations must be used. The basics of this process can be found in introductory books on computational chemistry. It's important to note that chemical bonding or structure cannot be understood purely in terms of electrostatics, as the forces on the nuclei are the only aspect that is purely electrostatic and cannot be derived from it.
Tclack
37
How do you determine the shape of molecules.
water, as an example, the 2 hydrogen atoms are at a 104.45 Degree angle from each other. But how is that calculated? I'm assuming it has something to do with the ratios of the electrostatic forces between the 2 hydrogen and the oxygen.
Well, first you must already know something about the shape, since geometry is just as much a part of what defines a compound as the elements its composed of. E.g. ethanol (CH3CH2OH) and dimethyl ether (CH3OC3) consist of the same atoms, but are completely different substances.
In practice, a chemist would just use empirical knowledge and simple models such as VSEPR. E.g. in the VSEPR picture, the oxygen atom in water has four electron pairs, two of which are bonding, so you would start with a tetrahedral angle of 109.47 degrees. Since free electron pairs repel more strongly than the ones involved in binding, this would be a bit shorter, so you'd expect 'a bit less than 109', which it indeed is. But these models are not quantiative, nor based on rigorous theory. If you want to calculate geometries from pure theory, then there's no way to do that other than an explicit quantum-mechanical calculation. (Even then, you still need a reasonable starting guess) Indeed, geometric parameters are often used to gauge the accuracy of quantum-chemical methods.
So, in short, you solve the Schrödinger equation within the Born-Oppenheimer approximation and get the energy in terms of nuclear coordinates, you can then calculate the derivatives with respect to those coordinates (analytically in many cases), and optimize the geometry w.r.t. energy using steepest-descent or some other numerical method. The basics are covered in pretty much any introductory book on computational chemistry. As I attempted to explain in another recent https://www.physicsforums.com/showthread.php?t=437978", chemical bonding or structure can't be understood in purely electrostatic terms. The only aspect of the system which is purely electrostatic are the forces on the nuclei, which is only of any use if you already know the electronic density, which you can't derive in terms of electrostatics.
1. How is the shape of a molecule determined?
The shape of a molecule is determined by the arrangement of its atoms and the bonds between them. This is influenced by the number of bonding and non-bonding electron pairs around the central atom.
2. What is the shape of a water molecule?
The shape of a water molecule is bent or V-shaped. This is due to the two bonding pairs and two non-bonding pairs of electrons around the central oxygen atom.
3. What is the bond angle in a water molecule?
The bond angle in a water molecule is approximately 104.5 degrees. This is the angle between the two hydrogen atoms, with the oxygen atom at the vertex.
4. How does the shape of a water molecule contribute to its properties?
The bent shape of a water molecule allows it to have a dipole moment, meaning it has a slight positive and negative charge on opposite ends. This contributes to its ability to form hydrogen bonds, making water a polar molecule and giving it unique properties such as high surface tension and high boiling point.
5. Can the shape of a molecule change?
Yes, the shape of a molecule can change in certain conditions such as changes in temperature or pressure. This can also occur through chemical reactions where bonds are broken and formed, resulting in a different molecular shape.
  • Atomic and Condensed Matter
