Shear and moments
  • Thread starter rsq_a
rsq_a
107
I can't seem to wrap my head around the signs of shears and moments when applied to beams. Consider a cantilever beam that goes from x = 0 to x = L (with positive deflection, or y(x), corresponding to a deflection upwards).
The standard equations tell us that
[tex]
\text{Moment} = EI \frac{d^2 y}{dx^2}
[/tex]
[tex]
\text{Shear} = EI \frac{d^3 y}{dx^3}
[/tex]
[tex]
\text{Load} = EI \frac{d^4 y}{dx^4}
[/tex]
Now consider what happens when we change [tex]x = -x[/tex] (that is, we put our coordinate system so that the beam begins at x = 0 and goes to x = -L).
Why does that change the shear to negative, but keep the sign of the moments and loads the same?
Answers and Replies
nvn
2,128
32
rsq_a: In post 1, it is somewhat unclear what "begins" means. Does "begins" mean the cantilever clamped support, in both cases you mentioned? Or does "begins" mean the cantilever free tip, in both cases?
skeleton
86
Apply a uniform load (UDL) across the span of a beam. Then apply the three equations you quoted. By the way, you could also add a fourth equation, first derivative which conveys curvature of the beam. Then you can note that the 1st and 3rd derivatives will yield opposite signed values if you reverse your coordinate, but remains equal for 2nd and 4th derivatives.
[tex]
\text{Curvature} = EI \frac{d^1 y}{dx^1}
[/tex]
The reason is that the loading (UDL) is symmetric across the coordinate span, by the choice of your loading example.
Now choose a non-symmetric loading pattern, say one-sided triangular loading which rises from zero at one end to max at other end. Then all four derivatives will give values that are not symmetric with regard to a change of the coordinate system.
Suggested for: Shear and moments
  • Last Post
48K
10K
  • Last Post
  • Last Post
12K
  • Last Post
