Comparing Aluminum & Copper Deflection Angles
In summary, the shear modulus for aluminum and copper is 25GPa and 35GPa, respectively. When subjected to the same shear force, the aluminum pole will have a deflection angle 1.52 times greater than the copper pole due to its lower shear modulus. This assumes that the poles are identical in proportions.
Loligo
The Shear modulus for aluminum and copper are 25GPa and 35GPa, respectively. An aluminum and copper pole, both the same length are subjected to the same shear force at the top of each pole, bending each pole a different angle y. Which pole has a higher angle of deflection and by how much?
Formulas I am using are Shear Modulus = Shear Stress/Shear Strain
S = σ/ε = (F/A)/(Δx/Lo)
angle y = ε = Δx/Lo
Since the forces are equal and area should be equal (under assumption the poles are the same dimensions the shear stress (σ) is equal for both poles.
Rearranging the formulas I get σ=S*y
σAC so 25GPa*yA=38GPa*yC
I get that the angle the deflection for the aluminum pole will be 1.52 times that of the copper pole.
is it 35 or 38 GPa? Insert correct value and round off to one decimal point, and your result will be OK. Shear stress is usually designated as [tex]\tau[/tex], and shear modulus is usually referred to as [tex]G[/tex]. This distinguishes it from normal stress ([tex]\sigma[/tex]) and elastic modulus ([tex]E[/tex]) used for normal strains.
The aluminum pole has a shear modulus of 25 GPa and the copper pole 35GPa.
Is it correct to say that the shear stress will stay the same with the poles are identical in proportions and are subjected to the same force
Yes. The problem does not specifically state that both poles are similar in cross section, so it must be assumed that they are identically proportioned..
This means that the aluminum pole will have a higher angle of deflection than the copper pole by 52%.
I would like to clarify that the units for shear modulus are in Pa (Pascals), not GPa (Gigapascals). Therefore, the correct values for aluminum and copper would be 25,000,000 Pa and 35,000,000 Pa, respectively.
With this correction, I agree with your solution that the aluminum pole will have a higher angle of deflection than the copper pole. This is because aluminum has a lower shear modulus, making it more flexible and easier to bend compared to copper. This also means that for the same applied force, the aluminum pole will experience a greater amount of shear strain compared to the copper pole, resulting in a higher deflection angle.
It's important to note that the exact deflection angle will also depend on other factors such as the dimensions and shape of the poles, as well as the type of force being applied. However, based on the given information, we can conclude that the aluminum pole will have a higher angle of deflection than the copper pole.
What is the difference between aluminum and copper deflection angles?
The main difference between aluminum and copper deflection angles is their material composition. Aluminum is a lightweight metal that is known for its high strength-to-weight ratio, while copper is a heavy metal with excellent electrical conductivity. This difference in material properties can affect the deflection angle of the two metals when subjected to a force.
Which metal has a higher deflection angle, aluminum or copper?
In general, aluminum has a higher deflection angle than copper. This is because aluminum has a lower density and higher strength, allowing it to withstand greater forces before bending. However, the specific deflection angle will also depend on the thickness and shape of the metal.
How do the properties of aluminum and copper affect their deflection angles?
As mentioned before, aluminum has a lower density and higher strength than copper, which contributes to its higher deflection angle. Additionally, aluminum has a higher yield strength, meaning it can withstand more stress before permanently deforming. On the other hand, copper has a higher ductility, meaning it can be bent or shaped more easily, resulting in a lower deflection angle.
Can the deflection angle of aluminum and copper be manipulated?
Yes, the deflection angle of both aluminum and copper can be manipulated through various methods. For example, changing the thickness of the metal or the shape of the structure can alter the deflection angle. Additionally, applying heat or cold can also impact the deflection angle of these metals.
What are some real-world applications of comparing aluminum and copper deflection angles?
The comparison of aluminum and copper deflection angles is important in various engineering and construction industries. For example, it can help determine the appropriate material to use in building structures or bridges, where deflection under load is a critical factor. It can also be useful in the design of electrical components, where the deflection of copper wires can affect their performance.
16K
9K
