Shear Problem?
  • Thread starter psycovic23
psycovic23
48
I have a problem that I'm not sure how to approach. "If the shear stress in steel exceeds about 4.00 x 10^8 N/m^2, the steel ruptures. Determine the shearing force necessary to (a) shear a steel bolt 1.00 cm in diameter and (b) punch a 1.00 cm diameter hole in a steel plate .500 cm thick.
I think I got A right (3.14x10^4, right?), but I'm stuck on B. I'm trying to use
[tex]\frac{F}{A} = S \frac{\Delta x}{h}[/tex]
but I don't know what to use for h. So far, I'm solving for F, A=pi*.005^2, S = 8.4x10^10, delta x = .500 cm, but I don't know what H is. Any ideas?
Answers and Replies
mathmike
208
wouldnt h be the thickness of theplate you are punching through?
psycovic23
48
But aren't I still missing one piece of information?
quark
231
Shear force is always perpendicular to the plane of the plate(or in simple terms, it acts in the plane of thickness) I am not sure about the basis of your equation. Calculate the lateral area of sheared material. Once you get the area, what relation holds stress to force?
Clue to your second question : What is left when you shear a bolt in the plate?
Suggested for: Shear Problem?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
