Homework Help: Shear stress in welding
  1. Dec 15, 2012 #1
    Femme_physics
    The depicted construct is made of a rod with a square cross-section and two plates. The plates are jointed together through 4 similar rivets. The square rod is welded to the wall at "B" and to the plates at the other end through peripheral corner welds.
    On the board acts an external force F = 6000 [N]
    A) Calculate the needed width of the welded area at B
    B) The rivets' diameter.
    Given:
    Allowable stress at welded area = 80 MPa
    Allowable shearing stress at the rivet = 60 MPa
    Allowable local compression at the rivets = 100 MPa
    http://img202.imageshack.us/img202/5481/lookad.jpg [Broken]
    2. Relevant equations
    http://img39.imageshack.us/img39/6965/equationssss.jpg [Broken]
    3. The attempt at a solution
    Can it be ths simple!?!?
    http://img845.imageshack.us/img845/6205/solsssss.jpg [Broken]
  3. Dec 15, 2012 #2
    PhanthomJay
    The equation for vertical shear in the weld is simple enough, but you are not applying it correctly. You should first calculate the end reactions before determining weld stresses. There will be a shear load, a bending moment, and a torsional moment. For the vertical shear , your value of the vertical reaction is correct, but you are incorrectly summing your l's. The l's are not related to the overhang length. They relate to the overall weld length at B.
  4. Dec 15, 2012 #3
    Femme_physics
    What do you mean by end reaction? Technical mechanics? Sum of all forces = 0?
    Hmm, I think I see what you're saying
    My "l" should be 800 + 80 + 80 + 80 + 80
    Since it's square shaped
  5. Dec 15, 2012 #4
    PhanthomJay
    At B, use sum of all forces acting vertical on the beam = 0 , to solve for the vertical end reaction at B. Use sum of all moments about an axis running thru B out of the plane of the paper to solve for the bending moment at B. Use sum of moments about an axis passing thru B along the length of the beam to solve for the torsional moment at B.
    why the extra 800?
  6. Dec 19, 2012 #5
    Femme_physics
    Thank you, noticed my mistake. Solved it for shearing :)
