Homework Help: Shear Stress Problem
  1. Apr 22, 2014 #1
    M_J
    The force on a knee cartilage can cause a large force to deform it. The cartilage area is 11cm^2 and the shear modulus is 12MPa. Max force at impact is 904N at an angle of 12 degrees with the cartilage, through what angle (in degrees) will the cartilage be deformed?
    2. Relevant equations
    http://session.masteringphysics.com/problemAsset/1026529/6/yg.11.35.jpg
    Shear modulus = Stress/Strain
    Stress = F(perpendicular)/A
    Strain = x/h
    3. The attempt at a solution
    Stress = 904sin(12)/11x10^-4
    Strain = 0.0142
    h=11x10-2 ??
    angle = tan^-1(0.0142/11x10-2) = 7.4
    This method appears a little wrong, is someone able to point out where I have gone wrong and how I should have got to the answer? Thanks! :-)
  3. Apr 22, 2014 #2
    SteamKing
    Staff Emeritus
    Your calculations are also units-free, which makes them even more difficult to follow.
  4. Apr 22, 2014 #3
    M_J
    All units are SI, stress has units of Pa, strain is a ratio so has no units and h is measured in metres. My angle is in degrees.
    I would be grateful if you were now able to help me with my answer! :-)
  5. Apr 22, 2014 #4
    Your angle calculation is incorrect. You already have the shear strain, so why are you dividing by the area?
    Chet
  6. Apr 22, 2014 #5
    M_J
    Thanks, can you explain what I do need to do then please?
  7. Apr 22, 2014 #6
    M_J
    Don't worry, I have done it now - thanks anyway!
  8. Apr 22, 2014 #7
    M_J
    Thanks!
  9. Apr 27, 2014 #8
    what exactly did you do to change your original setup? i can't figure this one out
Have something to add?
Draft saved Draft deleted
