SHM on a cylindrical trough
In summary, we can show that for small displacements, a solid sphere of radius R rolling without slipping in a cylindrical trough of radius 5R executes SHM with a period T=2\pi \sqrt{\frac{28R}{5g}}. However, there was a small mistake in the torque equation used, which was corrected to get the correct expression for T. Great job on solving the problem!
tsw99
35
SHM on a cylindrical trough (solved?)
A solid sphere of radius R rolls without slipping in a cylindrical trough of radius 5R. Show for small displacement, the sphere executes SHM with period [tex]T=2\pi \sqrt{\frac{28R}{5g}}[/tex]
[PLAIN]http://img299.imageshack.us/img299/8026/shmt.jpg
since it is rolling without slipping on the cylindrical trough, so [tex]\frac{ds}{dt}=4R\frac{d\theta}{dt}[/tex]
By 2nd law, the net force in tangential direction is [tex]mgsin\theta[/tex]
consider translational motion, [tex]-mgsin\theta=m\frac{d^{2}s}{dt^{2}}[/tex]
Edit:
I see the problem of the torque equation, the CM must always have zero angular velocity,
so the torque equation for the point touching with the trough, [tex]-mgsin\theta (R)=(\frac{2}{5}MR^{2}+MR^{2})\alpha[/tex]
where [tex]\alpha[/tex] is the angular acceleration of that point [tex]\alpha=\frac{a}{R}[/tex] where a is the acceleration of CM, which then leads to [tex]-\frac{gsin\theta}{R}=4\ddot{\theta}[/tex]
So I have [tex]-mgRsin\theta=\frac{28MR^{2}\ddot{\theta}}{5}[/tex] which leads to the correct expression?
Are there any mistakes I made? thanks
Hello,
Great job on solving the problem! Your approach seems correct and your final expression for the period T is also correct.
However, there is a small mistake in your solution. The net torque equation that you used (-mgsin\theta (R)=(\frac{2}{5}MR^{2}+MR^{2})\alpha) is actually for a solid sphere rolling without slipping on a flat surface. In this problem, the sphere is rolling without slipping in a cylindrical trough, so the torque equation will be slightly different.
The net torque equation for this problem would be:
-Tsin\theta R=(\frac{2}{5}MR^{2}+MR^{2})\alpha
Where T is the tension in the string and \alpha is the angular acceleration of the sphere.
Substituting this into your expression, we get:
-\frac{TRsin\theta}{MR}=\frac{28R\ddot{\theta}}{5}
Solving for T, we get:
T=\frac{28MR}{5sin\theta}\ddot{\theta}
Now, we know that for small displacements, \theta is very small, so we can approximate sin\theta \approx \theta.
Substituting this into our expression for T, we get:
T=\frac{28MR}{5\theta}\ddot{\theta}
Now, we also know that for small displacements, the angular acceleration \ddot{\theta} is directly proportional to the displacement \theta, so we can write:
\ddot{\theta}=-\omega^{2}\theta
Where \omega is the angular frequency.
T=\frac{28MR}{5\theta}(-\omega^{2}\theta)
Simplifying this, we get:
Which is the correct expression for the period T.
So, in conclusion, your approach was correct, but there was a small mistake in your torque equation. Keep up the good work!
1. What is SHM on a cylindrical trough?
SHM (Simple Harmonic Motion) on a cylindrical trough refers to the oscillatory motion of a particle or object along the curved surface of a cylinder. This type of motion is characterized by a restoring force that is directly proportional to the displacement of the object from its equilibrium position.
2. What factors affect SHM on a cylindrical trough?
The amplitude of the oscillation, the mass of the object, the radius of the cylinder, and the strength of the restoring force all affect SHM on a cylindrical trough. In addition, the initial conditions of the object's motion, such as its initial displacement and velocity, also play a role in the motion.
3. How is the period of an object's motion on a cylindrical trough calculated?
The period of an object's motion on a cylindrical trough is calculated using the formula T = 2π√(m/k), where T is the period, m is the mass of the object, and k is the spring constant of the restoring force. This formula assumes that the motion is ideal and there is no friction or other external forces acting on the object.
4. What is the relationship between SHM on a cylindrical trough and simple pendulum motion?
SHM on a cylindrical trough and simple pendulum motion are both examples of periodic motion. However, the restoring force in SHM on a cylindrical trough is linear (proportional to displacement), while the restoring force in a simple pendulum is non-linear (proportional to the sine of the displacement). This results in slightly different equations and behaviors for the two types of motion.
5. How does SHM on a cylindrical trough relate to real-life phenomena?
The motion of a pendulum, such as a grandfather clock, can be approximated as SHM on a cylindrical trough. Similarly, the motion of a roller coaster along a curved track can also be described using SHM on a cylindrical trough. In both cases, the restoring force is provided by gravity pulling the object back towards its equilibrium position.
