Homework Help: Shm physics help
  1. Jan 12, 2007 #1
    A wedge of mass M is placed on a rough surface with a mass m attached to a spring placed rigidly on the wedge. The surface b/w the wedge and the mass m is smooth and the surface between the wegde and the ground is sufficiently rough to keep the wedge from moving. The angle of inclination of the wedge w.r.t ground is 60 degrees. The small block is displaced by a small distance x. Find the force of friction between the ground and the wedge.
    2. Relevant equations
    [tex]\frac{d^2 x}{dt^2)=-kx[/tex]
    [tex]x=asin(\omega t)[/tex]
    3. The attempt at a solution
    Force acting on the mass m :
    [tex]F=-kx[/tex]
    Force along the horizontal direction:
    [tex]F=-kxcos(60)[/tex]
    [tex]F=-\frac{1}{2}kx[/tex]
    [tex]m\frac{d^2x}{dt^2}=-\frac{1}{2}kx[/tex]
    [tex]\frac{d^2x}{dt^2}=-\frac{1 k}{2 m}x[/tex]
    [tex]a=-\frac{k}{2m}asin(\omega t)[/tex]
    [tex]\frac{k}{m}=\omega ^2[/tex]
    [tex]f_r=Ma[/tex]
    [tex]f_r=\frac{1 Ma\omega ^2sin(\omega t)}{2}[/tex]
    but the answer given is [tex]f_r=\frac{ma\omega ^2sin(\omega t)}{2}[/tex]
    Is the book wrong or have I made a mistake?
  3. Jan 12, 2007 #2
    cristo
    Staff Emeritus
    Are you using a to mean two different things here?
  4. Jan 15, 2007 #3
    Yeah, sorry. In the end it should be A, for amplitude.
Loading...
