B Short check on solved ODE problem
  • Thread starter Silviu
Hello! I have this problem f'(x)=f(2-x) and I need to find f. This is what I did
x -> 2-x
f'(2-x)=f(2-2+x)=f(x) => f''(x)=f'(2-x)=f(x) => f''(x)=f(x) => ##f(x)=c_1e^x+c_2e^{-1}##.
So, ##c_1e^x-c_2e^{-x}=c_1e^{2-x}+c_2e^{x-2}## => ##-c_2e^{-x}=c_1e^2e^{-x}## => ##-c_2=c_1e^2##. And, similarly, ##c_1=c_2e^{-2}##. So ##-c_2=c_2e^2e^{-2}## => ##c_2=c_1=0## => f(x)=0.
Is this correct? There is another solution? Thank you!
32,573
4,303
x -> 2-x
I see three problems.
1) You replaced x by 2 -x, but you aren't consistent with this change. If you make a substitution, use a variable with a different name.
2) From f''(x) = f(x) (which does not follow from the original diff. equation), the general solution should be ##f(x)=c_1e^x+c_2e^{-x}##, which is different from what you have.
3) In your work below, you solve for the coefficients c1 and c2. Since there are no initial conditions given, there's no way to solve for these constants.
Want to reply to this thread?
"Short check on solved ODE problem" You must log in or register to reply here.
Related Threads for: Short check on solved ODE problem
  • Posted
  • Posted
M
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
