Effect of Heat on Hole Diameter in Steel - Short Question for Homework (2 Marks)
In summary, as a hole is drilled through a piece of steel and the steel is heated, the diameter of the hole decreases due to the expansion of the outer circumference and contraction of the inner circumference. This can be demonstrated by the example of a piece of paper with a 0.5" diameter hole being enlarged and the measurements showing a decrease in diameter.
sovankc
this is a 2 marks question
a hole is drilled through a piece of steel what happens to the diameter of the hole as the steel is heated
i guess the diameter of the hole decreases as both the outer as well as inner circumference are free the outer circumference expands outside and inner circumference towards in resulting the hole to be small.....
What do you mean outer circumference? is it a sheet with a hole in it or a ring?
Take a piece on paper and make a 2" x 2" square. In the center, draw a 0.5" diameter hole. Go to a photocopy machine and enlarge it by 30% or 40% or whatever is handy. Then measure the sides of the new square and the diameter of the hole. What happened?
hi neu
it is a solid steel
1. What is heat?
Heat is a form of energy that is transferred between objects or systems due to a difference in temperature.
2. How is heat measured?
Heat is measured in units of energy, such as joules or calories. It can also be measured using a thermometer, which measures the temperature of an object or system.
3. What are the different ways heat can be transferred?
Heat can be transferred through conduction, convection, and radiation. Conduction is the transfer of heat through direct contact between objects, convection is the transfer of heat through the movement of fluids, and radiation is the transfer of heat through electromagnetic waves.
4. How does heat affect matter?
Heat can cause changes in the physical properties of matter, such as changing its state from solid to liquid or gas. It can also cause objects to expand or contract.
5. What is the relationship between heat and temperature?
Heat and temperature are related but not the same. Temperature is a measure of the average kinetic energy of particles in a substance, while heat is the total energy contained in a substance. When heat is added to a substance, its temperature usually increases.
22K
