Show F is isomorphic to F/{0}
Let F be a field. Show that F is isomorphic to F/{0}
By the first ring isomorphic theorem, kernel of the homomorphism is an ideal which is either {0} or I. Hence F isomorphic to F/{0}
I think I misunderstood the problem can anyone check my work where I did wrong
Answers and Replies
STEMucator
2,075
140
For two fields to be isomorphic, there has to be a bijective homomorphism between them:
$$\phi : F \rightarrow (F - \{0\})$$
You need to define the map you used to show ##\text{ker}(\phi)## is an ideal of ##F##. You then need to show ##\ker(\phi)## really is an ideal.
Then I would be convinced.
You could also go the long way by proving the map you've defined is a bijective homomorphism between the fields, which would imply the fields are isomorphic to each other.
Suppose $\phi : F\rightarrow F$ is an identity homomorphism, then $\ker(\phi)=\{0\}$ is an ideal of $F$ and hence $F/\{0\}\cong F$ by the first ring isomorphism.
STEMucator
2,075
140
Are you saying ##\phi(f) = f, \forall f \in F##? If so there is a problem because ##\phi(0) = 0## and ##0 \notin (F - \{ 0 \})##.
3,297
The OP means ##F/\{0\}##, which means the ring ##F## modulo ##\{0\}##. He does not mean the set theoretic difference ##F\setminus \{0\}## (in that case, the result in the OP is obviously false).
3,297
Correct.
STEMucator
2,075
140
Oh I thought the OP was intending to mean the set theoretical difference.
I never knew \setminus was the way to do that, so I guess I learned something too.
The OP is correct if they were intending modulo, but I definitely would have been a bit more explicit when asking.
3,297
I agree, I was very confused too.
Related Threads on Show F is isomorphic to F/{0}
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
