Proving ad-bc ≠ 0: RREF Matrix Solution | Step-by-Step Guide
  • Thread starter icesalmon
In summary, if ad-bc ≠ 0, then the reduced row echelon form of the 2x2 matrix [a b; c d] is the identity matrix [1 0; 0 1]. This can be achieved by using row operations to divide each row by (ad-bc), without any concern for impossibilities such as dividing by 0.
icesalmon
270
Show that if ad-bc ≠ 0 then
RREF[a b] = [1 0]
[c d] [0 1]
I cannot use any equivalent statements here, and I don't "know" what a determinant is yet so I have to show this in another way.
I start off by saying if ad - bc ≠ 0 then I can say ad - bc = "e" whether it's positive or negative, I'm not sure, is important. So what I tried was using some substitution and got
a = ( e + bc ) / d
b = ( ad -e ) / c
c = ( ad - e ) / b
d = ( e + bc ) / a
and creating a little 2 x 2 matrix with the RHS, it got too messy and I wasn't even sure what I was doing would work so I stopped with that.
then I went back to ad - bc = ±e and tried working on some ideas with inequalities for instance if ad - bc = +e then I know ad > bc and if ad - bc = -e then I know ad < bc and this is where I get stuck. I'm not sure if any of this is on the right track, but as always, I've come to PF to untangle my mangle. Thanks for the help.
The little scribble at the end of the problem statement is supposed to be a 2x2 matrix row reducing to the identity.
RREF[a b] = [1 0]
[c d] [0 1]
The two matrices are
$$ \begin{bmatrix} a & b\\ c & d\end{bmatrix}$$
and
$$ \begin{bmatrix} 1 & 0\\ 0 & 1\end{bmatrix}$$
a = ( e + bc ) / d
b = ( ad -e ) / c
c = ( ad - e ) / b
d = ( e + bc ) / a
You don't need to worry about ad - bc being positive or negative; just whether it ad - bc = 0 or ad - bc ≠ 0. What I would do is actually row-reduce your first matrix. You should see in a short time what effect the value of ad - bc has on what you get.
okay so I'm row reducing \begin{bmatrix} a & b\\ c & d\end{bmatrix}
and I get\begin{bmatrix} (ad-bc) & 0\\ 0 & (ad-bc)\end{bmatrix}
and I'm concerned about ad - bc and it's relationship with 0. Well if ad - bc = 0 then we don't get the 2x2 identity, so how do I show it's exactly equal to one and not some other number?
Am I just setting:
equal to
\begin{bmatrix} 1 & 0\\ 0 & 1\end{bmatrix} and calling it finished?
You don't have to show that ad - bc = 1. All you need to know is that ad - bc ≠ 0. As long as that's true, you can multiply each row by 1/(ad - bc), which gives you 1 for the upper left and lower right entries in the matrix.
icesalmon said:
Am I just setting:
equal to
There are three row operations that you can use to row-reduce a matrix:
1. Adding a multiple of one row to another.
2. Interchaning two rows.
3. Replacing a row by a nonzero multiple of itself.
The matrix that you end up with after doing these operations is equivalent to, but not equal to, the one you started with.
so based on the condition, that we assume from the start, which is ad - bc isn't equal to 0 we can divide out the ( ad - bc ) terms to make it equal to the identity without having to worry about any impossibilities: 1/0
working off of #3 there.
It would help if I were to pay more attention to the problem statement from now on.
Thanks, Mark
Pretty much.
That's always good advice!
icesalmon said:
Thanks, Mark
You're welcome
1. What does the condition "ad-bc ≠ 0" mean?
The condition "ad-bc ≠ 0" means that the product of two numbers, ad and bc, is not equal to zero. In other words, at least one of the numbers must be non-zero for the condition to be satisfied.
2. Why is it important to show that ad-bc ≠ 0?
It is important to show that ad-bc ≠ 0 because this condition is often used in mathematical proofs and equations. It indicates that certain calculations or steps can be performed without encountering a division by zero error, which is undefined in mathematics. It also helps to ensure the validity and accuracy of mathematical statements.
3. How can you prove that ad-bc ≠ 0?
To prove that ad-bc ≠ 0, you can use algebraic manipulation and properties of numbers. Start with the assumption that ad-bc = 0 and then work towards a contradiction by showing that this leads to a logical inconsistency or impossibility. Alternatively, you can also prove this condition by providing specific examples or counterexamples.
4. What are some real-world applications of the condition "ad-bc ≠ 0"?
The condition "ad-bc ≠ 0" has various real-world applications, such as in economics, physics, and engineering. In economics, it is used in analyzing supply and demand curves, while in physics, it is used in calculating moments of inertia. In engineering, it is used in solving systems of linear equations and in determining the stability of control systems.
5. Can the condition "ad-bc ≠ 0" be rewritten in a different form?
Yes, the condition "ad-bc ≠ 0" can be rewritten in different forms, such as "a ≠ 0 and d ≠ 0", "a ≠ 0 or d ≠ 0", or "ad ≠ bc". These forms all convey the same meaning that at least one of the numbers a, b, c, or d must be non-zero for the condition to hold.
  • Linear and Abstract Algebra
