Proving the Maximum of a Cubic Polynomial: Solving for Cases of Equality
  • Thread starter .d9n.
In summary, to show that M = max|f(x)| ≥ 1/4 on the interval -1 ≤ x ≤ 1 for the function f(x) = x^3 + ax^2 + bx + c, we need to find the critical points of the function and determine if they lie within the interval. The critical points can be found by setting the first derivative equal to 0 and solving for x. Based on the discriminant of the quadratic formula, we can determine the number of critical points and whether or not they lie within the given interval. This will give us the necessary information to prove that M ≥ 1/4.
.d9n.
61
Let f(x) = x^3+ ax^2+ bx + c with a, b, c real. Show that
M = max|f(x)|≥1/4
-1 ≤ x ≤ 1
and find all cases where equality occurs.
|(-1 ≤ x^3 ≤ 1)+(-a ≤ ax^2 ≤ a)+(-b ≤ bx ≤ b)+c|≥1/4?
not sure how to prove without knowing what a,b,c are?
M = max|f(x)|≥1/4
-1 ≤ x ≤ 1
Adding inequalities (which are either true or false) doesn't make any sense.
Basically, what you need to show is that the largest value of |f(x)| on the interval -1 <= x <= 1, is at least 1/4.
Wouldn't the derivative be useful here?
thanks
so i have
f '(x)=3x^2 + 2ax + b
f ' (x) =0 to find critical values
= -1/3a ± (√(4a^2 -12b))/6
not entirely sure where to go from here
.d9n. said:
thanks
so i have
1. When you start a line with =, you are saying that what is just above equals what's to the right of the = sign. In this case, you are saying that
0 = -1/3a ± (√(4a^2 -12b))/6
This is not true.
When you solved using the quadratic formula, what did you solve for?
2. There is an error what you did with the quadratic formula.
sorry i meant x= (-2a±√(4a^2-12b))/6,
not sure where I have gone wrong with the formula though (-b±√(b^2-4ac))/2a, correct?
although I am not too sure how this helps me
im not meant to do this:
(-1/3a ± (√(4a^2 -12b))/6)^3+ a(-1/3a ± (√(4a^2 -12b))/6)^2 +b(-1/3a ± (√(4a^2 -12b))/6)+c
surly?
That's better.
So what are the conditions for which f'(x) = 0? Will there be no such x-values, 1 such x-value, or 2 separate x-values?
No
.d9n. said:
surly?
surly and surely are different words. Unless I miss my guess, you meant "surely."
yes i meant surely, sorry.
there will be two x values, assuming a,b≠0 i think
im unsure of how to work out what these x values are when we don't know what a and b are.
Is the second derivative useful once we have found out what the x values are to find the max
f''(x)=6x+2a
No, not true. If a = b = 2, there are no values for which f'(x) = 0.
Like I asked before, what are the conditions for which f'(x) = 0? For what values of a and be will there be no critical points, 1 critical point, or 2 separate critical points?
The Quadratic Formula gives you more information than you are using.
Also, all you are given is that a and b are real. You can't assume they aren't zero.
The issue is not *just* whether there are two critical values of x, but whether or not these two values lie between -1 and +1. On the interval [-1,1], you may have: (i) no stationary point in (-1,1)(so the max/min occur at an endpoint x = +- 1); (ii) one stationary point in (-,1,1) and the other outside it (so the min occurs in (-1,1) and the max at +- 1, or vice-versa); (iii) two stationary points in (-1,1) (so that the max may occur in (-1,1) or at an endpoint, and similarly for the min.) Somehow you need to straighten out these possibilities.
RGV
the conditions are that the function has a maximum at x=n if f'(n)=0 and f''(0) is negative
it won't have any critical points when
-2a + √(4a^2 -12b)=0 so when a,b=0
it will have two critical point when
-2a - √(4a^2 -12b)=0 → b=2/3a^2 and a=√(3b/2)?
how am i meant to work out if the critical values lie in between -1 and 1, without know what a and b are. Sorry it all getting quite confusing
Not quite, but you're getting warmer. There won't be any critical points when the discriminant < 0. When will there be one critical point? Two distinct critical points?
And as Ray pointed out, it makes a difference whether these points are in (-1, 1) or not.
if the discriminant is > 0, the polynomial has two real roots, if the discriminant is = 0, the polynomial has one real root, and if the discriminant is < 0, the polynomial has no real roots
so therefore
if 4a^2-12b>0 it has two real roots so 0<4a^2-12b<=1,
if 4a^2-12b=0 it has one real root so 4a^2-12b=0
if 4a^2-12b<0 it has no real roots so -1<=4a^2-12b<0
is this what you mean?
when you say it makes a difference whether or not the points are in (-1,1) is this because its stated that x has to be in these points in the qu?
or is it something i have missed?
also what am i meant to do now, am i meant to solve for a and b?
so therefore
Yes and no, but mostly no.
What has two real roots? Be specific. Don't use the word "it".
Why do you think that 4a2 - 12b <= 1? Where did that come from?
if 4a^2-12b=0, then of course if 4a^2-12b=0.
Again, what has one real root?
Why do you think that 4a2 - 12b >= -1?
when i say it i mean the derivative of f'(x) or should i be working out the discriminant of f(x), i.e. b^2 c^2-4ac^3-4b^3d-27a^2d^2+18abcd
so in our case would be
a^2b^2-4b^3-4a^3-27c^2+18abc,
and i realize what wrong with the <=1 and >=1, i was thinking about x.
so therefore it woudl mean the polynomial
.d9n. said:
so therefore it would mean the polynomial
Which polynomial?
There are two critical numbers (in addition to where f '(x)=0) for the interval [-1, 1].
They correspond to the end points of the interval. They are especially important if f '(x) has no roots on the interval [-1, 1] .
No offense, but this problem seems way beyond your abilities. The idea of the discriminant in a quadratic equation does not extend to cubic polynomials, which is what f(x) is. I think that your best strategy might be to sit down with your instructor.
1. What does the expression "Max|f(x)|>=1/4" mean?
The expression "Max|f(x)|>=1/4" means that the maximum value of the absolute value of the function f(x) is greater than or equal to 1/4.
2. How do you interpret the inequality "Max|f(x)|>=1/4" graphically?
Graphically, the inequality "Max|f(x)|>=1/4" means that the graph of the function f(x) either never falls below the horizontal line y=1/4 or it touches the line at least once.
3. What is the significance of proving "Max|f(x)|>=1/4"?
Proving "Max|f(x)|>=1/4" can be significant in various fields of science and mathematics. It could help in analyzing the stability of a system, determining the convergence of a series, or proving the existence of solutions to certain equations.
4. How can you prove "Max|f(x)|>=1/4"?
The proof of "Max|f(x)|>=1/4" depends on the specific function f(x) and the context in which it is being used. In general, it involves using mathematical techniques such as calculus, algebra, or geometry to show that the maximum value of the absolute value of the function is greater than or equal to 1/4.
5. What are some real-life applications of "Max|f(x)|>=1/4"?
The concept of "Max|f(x)|>=1/4" can be applied in various real-life scenarios such as analyzing the stability of a bridge, determining the maximum load a structure can handle, or calculating the maximum profit a company can make. It can also be used in fields such as signal processing, image analysis, and data compression.
  • Math POTW for Secondary and High School Students
