Homework Help: Show that X+Y is normal
  1. Aug 28, 2010 #1
    If X and Y have a bivariate normal distribution with correlation p, show that X +Y is normally distributed
    This seems like a pretty standard proof but cant find it anywhere. Simply adding the marginal distributions, X+Y is what I tried but how is the correlation coefficient introduced?
  3. Aug 28, 2010 #2
    lanedance
    you need to start wth the joint pdf, which will contain info about the correlation
  4. Aug 28, 2010 #3
    If I change variables, U=X+Y and V=X-Y and take the jacobian, I can then take the marginal to find f_U.
    However, how do you change the standard deviation and means when you perform change of variables?
  5. Aug 29, 2010 #4
    Unfortunately this approach doesnt seem to work. I end up with a very messy exponential which doesnt allow separation for the marginal calculation :(
    Any thoughts? Is this not a standard proof?
  6. Aug 29, 2010 #5
    lanedance
    if X & Y have bivariate normal distribution (correlated), they can be wrtten in terms of 2 independent normal variables, say U & V, say:
    X = aU + bV
    Y = cU + dV
    it should follow that Z = X+Y = (a+c)U + (b+d)V is a sum of 2 independent normal distributions & thus is normal
    so if you know (or can show) the first part, you're there
  7. Aug 29, 2010 #6
    statdad
    You don't need to change them. Write out the joint distribution of X and Y, perform the transformation you describe, substitute, and then integrate out V. The integration will require you to complete the square in the exponent, and rewrite things as a single density.
  8. Aug 30, 2010 #7
    Thanks a lot for your replies. After making the substitution, there just isn't a way to minimize (completing the square or otherwise) because we have uv terms with different divisors. Is the approach rather to take u=x+y and v=something else? Is the choice of v the key?
    Has anyone actually ever done this proof?
    Please see Wolfram alpha link. No minimizing was possible
    http://www.wolframalpha.com/input/?...u-v)-c)^2/d^2-2p((0.5(u+v)-a)(0.5(u-v)-c))/bd
  9. Aug 30, 2010 #8
    lanedance
    if you find the linear combinations that diagonalises the covariance matrix, those represent the independent variables, and you can do as i suggeseted in 5
  10. Aug 30, 2010 #9
    lanedance
    note if they have mean 0 & variance 1 the covariance matrix is
    [tex]
    \Sigma = \begin{pmatrix} 1 & \rho \\ \rho & 1 \end{pmatrix}
    [/tex]
    with [itex] \textbf{x}^T = (x,y)^T [/itex] the joint pdf is proportional to
    [tex]
    f_{X,Y}(x,y) = e^{ \frac{1}{2(1-\rho^2)} ( \textbf{x}^T \Sigma \textbf{x} ) }
    [/tex]
    then eignevectors of sigma, say [itex] \textbf{u}^T = (u,v)^T [/itex] are the independent RVs, that is their Joint pdf can be written as:
    [tex]
    f_{U,V}(u,v) = e^{ (\frac{u}{\sigma_u})^2} e^{ (\frac{v}{\sigma_v})^2}
    [/tex]
    this should be easy to show what you require, however statdads may save a step
  11. Aug 30, 2010 #10
    lanedance
    or how about trying what statdad suggested
    [tex]
    f_Z(z) \approx \int \int dx dy \delta (z-x-y) e^{-x^2 -y^2 + 2 \rho x y }
    [/tex]
    [tex]
    = \int dx e^{x^2 -(z-x)^2 + 2 \rho x (z-x) }
    [/tex]
    [tex]
    = \int dx e^{-2(1+\rho)(x^2-zx + z^2) }
    [/tex]
    [tex]
    = \int dx e^{-2(1+\rho)(x^2-zx + (\frac{z}{2})^2+(\frac{z}{2})^2) }
    [/tex]
    [tex]
    = \int dx e^{-2(1+\rho)(x-\frac{z}{2})^2} e^{-2(1+\rho)(\frac{z}{2})^2 }
    [/tex]
  12. Aug 30, 2010 #11
    Lanedance, Thanks for your replies.
    I believe what Statdad was referring to was the joint PDF of a bivariate distribution i.e. http://upload.wikimedia.org/math/b/1/0/b10ecc56f758b2f94a953e7e1bd2f1c2.png
    In proving that X+Y is normal and where X and Y are dependent, not sure how you ignored the standard deviation in the dirac delta approach? In any case, when performing the final integration wrt x from -inf to inf doesnt yield the correct answer (probably my error somewhere)
    I understand the approach Statdad outlined from the joint pdf but the problem is in completing the square to obtain the form that will allow integration giving the error function...
  13. Aug 30, 2010 #12
    lanedance
    sorry, i assumed mean zero variance one, and dropped any constants for simplicity, i though you could add them in later if the method works
    anyway, taking off where we let off
    [tex]= \int dx e^{-2(1+\rho)(x-\frac{z}{2})^2} e^{-2(1+\rho)(\frac{z}{2})^2 }[/tex]
    now you can move the last z term outside of the x integral
    [tex]=e^{-2(1+\rho)(\frac{z}{2})^2 } \int dx e^{-2(1+\rho)(x-\frac{z}{2})^2[/tex]
    the integrand is then just the pdf of a normal variable, so should yield the same constant (1 if it were correctly normalised) regardless of z value, the z term just shifts the mean of the distrubtion
  14. Aug 30, 2010 #13
    Hi Lanedance
    Integrating the final part wrt x gives:
    sqrt(pi)/sqrt(2p+2) * exp(-2(1+p)(z/2)^2)
    The sqrt(2p+2) is correct as the correlation component of the summation. Does the rest look OK?
  15. Aug 30, 2010 #14
  16. Aug 30, 2010 #15
    lanedance
    as i said I didn't indcude any constants (they're only for normalisation only, its the form that is important),
    so if you want to get it exactly right you need to start with a correctly normalised distribution
  17. Aug 30, 2010 #16
    I see. Understood. Thanks a lot for taking the time to answer my questions. Appreciate it
  18. Aug 30, 2010 #17
    lanedance
    no worries
